Thanks.
Its a support library as far as I can tell.
source: https://groups.nscl.msu.edu/controls/files/devSnmp.html
download: https://groups.nscl.msu.edu/controls/
I think renaming to snmpSup is more self-explanatory, that way
the Makefile stays default ... nobody reads Makefiles, or check
for irregularities. :>
another quick question: how can I tell EPICS to static compile
the support library?
It uses some system library that needs additional compiler flags,
and I would have to repeat them in the IOC-generating App...
cheers!
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 10.06.24 um 19:57 schrieb Ralph
Lange via Tech-talk:
On Mon, 10 Jun 2024 at 19:47, William Kirstaedter
via Tech-talk < [email protected]>
wrote:
my main App is called IOCINFRAApp, the support App is called
snmpApp.
the build system now tries to compile IOCINFRAApp first, and
fails
because a dbd file from snmpApp is not yet available.
I've renamed my snmpApp to 0snmpApp and it works, but thats
too hacky in
my eyes.
Is there some more elegant way to achieve that snmpApp gets
built before
IOCINFRAApp ?
In general:
There are applications that generate IOCs, and there are
support applications that provide things (libraries,
templates) to be used by IOC-creating apps.
If the IOC-creating kind are called *App and the support
applications are called *Sup, the default order (first *Sup,
then *App) will work.
Specifically:
You can always declare a dependency that is not covered
by the default build order in the Makefile. In your case,
Cheers,
~Ralph
smime.p7s
Description: Kryptografische S/MIME-Signatur
- RE: epics build system question again - build order Mark Rivers via Tech-talk
- Re: epics build system question again - build order Johnson, Andrew N. via Tech-talk
- epics build system question again - build order William Kirstaedter via Tech-talk
- Re: epics build system question again - build order Ralph Lange via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
