1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: epics build system question again - build order
From: William Kirstaedter via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "Johnson, Andrew N." <[email protected]>, Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 10 Jun 2024 21:09:12 +0200
ahh Freddie has a modified version https://github.com/ISISComputingGroup/EPICS-devSnmp
well, too late :>
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 10.06.24 um 20:45 schrieb William Kirstaedter via Tech-talk:
Thank you guys for the quick answers.
as you promised, my netsnmp library only exists as a shared one, so the build still fails with stuff like
/usr/bin/ld: /home/epics/FHI/IOCINFRA/lib/linux-x86_64/libdevSnmp.so: undefined reference to `usmAESPrivProtocol'
I guess then I dont get around doubling the compiler flag lines.
cheers,
William Kirstaedter
Am 10.06.24 um 20:37 schrieb Mark Rivers:
Sorry, Andrew is right, to build the support library statically only use SHARED_LIBRARIES=NO.
STATIC_BUILD=YES would be used in the IOC application Makefile to tell it to link with static support libraries, so the executable does not depend on any EPICS shareable libraries.
From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: Monday, June 10, 2024 1:27 PM
To: William Kirstaedter <[email protected]>; Ralph Lange <[email protected]>; EPICS Tech Talk <[email protected]>
Hi William,
If you edit the Makefile which creates the library and set SHARED_LIBRARIES=NO that will tell the build system to not generate any lib*.so files when building that library. The IOC-generating app will still need to link with the shared libraries from upstream (snmp etc.), but it sounds like that would work for you.
- Andrew
On 6/10/24, 2:18 PM, "Tech-talk" <[email protected]> wrote:
Thanks.
Its a support library as far as I can tell.
source: https://groups.nscl.msu.edu/controls/files/devSnmp.html
download: https://groups.nscl.msu.edu/controls/
I think renaming to snmpSup is more self-explanatory, that way the Makefile stays default ... nobody reads Makefiles, or check for irregularities. :>
another quick question: how can I tell EPICS to static compile the support library?
It uses some system library that needs additional compiler flags, and I would have to repeat them in the IOC-generating App...
cheers!
William Kirstaedter
Am 10.06.24 um 19:57 schrieb Ralph Lange via Tech-talk:
On Mon, 10 Jun 2024 at 19:47, William Kirstaedter via Tech-talk <[email protected]> wrote:
my main App is called IOCINFRAApp, the support App is called snmpApp.
the build system now tries to compile IOCINFRAApp first, and fails
because a dbd file from snmpApp is not yet available.
I've renamed my snmpApp to 0snmpApp and it works, but thats too hacky in
my eyes.
Is there some more elegant way to achieve that snmpApp gets built before
IOCINFRAApp ?
In general:
There are applications that generate IOCs, and there are support applications that provide things (libraries, templates) to be used by IOC-creating apps.
If the IOC-creating kind are called *App and the support applications are called *Sup, the default order (first *Sup, then *App) will work.
Specifically:
You can always declare a dependency that is not covered by the default build order in the Makefile. In your case,
IOCINFRAApp_DEPEND_DIRS += snmpApp
Cheers,
~Ralph
Attachment: smime.p7s
Description: Kryptografische S/MIME-Signatur
RE: epics build system question again - build order Freddie Akeroyd - STFC UKRI via Tech-talk
epics build system question again - build order William Kirstaedter via Tech-talk
Re: epics build system question again - build order Ralph Lange via Tech-talk
Re: epics build system question again - build order William Kirstaedter via Tech-talk
Re: epics build system question again - build order Johnson, Andrew N. via Tech-talk
RE: epics build system question again - build order Mark Rivers via Tech-talk
Prev: Re: epics build system question again - build order William Kirstaedter via Tech-talk
Next: automatically start the IOC via procServ 周逸媚 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: RE: epics build system question again - build order Freddie Akeroyd - STFC UKRI via Tech-talk
