1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Building EPICS 7
From: John Dong via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Mon, 17 Jun 2024 12:44:24 -0400
I encountered the missing CCL.OBJ error when building epics-base. The problem still exists with the current version of Strawberry Perl.
John Dong/Princeton Plasma Physics Lab
Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj)
From:Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
@Ralph  I see this is using an older ActiveState Perl, is that configurable somehow? The latest StrawberryPerl packages (available through Chocolatey) install GNU Make-4.2.1 (named "gmake") and gcc as well, so they provide everything we need for a MinGW build. That's what I'm using here and had no problems with.
RE: Building EPICS 7 Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: AreaDetector Pva problem Jörn Dreyer via Tech-talk
Next: RE: Building EPICS 7 Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: AreaDetector Pva problem Mark Rivers via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
