Hi, are you building with visual studio or mingw? I’ve seen this error before when building with visual studio and the compiler (cl.exe) is not found in the windows PATH, it might
be the same can occur with mingw if it can’t locate the compiler either. Could you please post the output of your build showing the error message and lines of output displayed on screen prior to the error
Freddie
On Behalf Of John Dong via Tech-talk
Sent: Monday, June 17, 2024 5:44 PM
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Subject: Building EPICS 7
I encountered the missing CCL.OBJ error when building epics-base. The problem still exists with the current version of Strawberry Perl.
John Dong/Princeton Plasma Physics Lab
Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj)
Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
@Ralph I see this is using an older ActiveState Perl, is that configurable somehow? The latest StrawberryPerl packages (available through Chocolatey) install GNU Make-4.2.1 (named "gmake") and gcc as well, so they provide everything we need for a MinGW build. That's what I'm using here and had no problems with.
- Re: [External] RE: Building EPICS 7 John Dong via Tech-talk
- Building EPICS 7 John Dong via Tech-talk
<2024>
2025
<2024>
2025
ANJ, 11 Sep 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
