1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: Strange problem with EPICS areaDetector
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 19 Jun 2024 10:58:20 +0200
Hi Ralph,
at least the IOC can loads the database without bailing out directly, but still there seems to be another problem:
#9  0x00007ffff7d8ab4e in strncpy (__len=40, __src=<optimized out>, __dest=<optimized out>)
    at /usr/include/x86_64-linux-gnu/bits/string_fortified.h:95
#10 get_enum_strs
    (options=0x7fffae5ff2c0, prset=0x7ffff7e48580 <aiRSET>, ppbuffer=<synthetischer Zeiger>, paddr=0x7fff8c06b960)
    at ../db/dbAccess.c:192
#11 getOptions (pflin=0x0, options=0x7fffae5ff2c0, poriginal=<synthetischer Zeiger>, paddr=0x7fff8c06b960)
    at ../db/dbAccess.c:415
#12 dbGet
    (paddr=paddr@entry=0x7fff8c06b960, dbrType=dbrType@entry=11, pbuffer=pbuffer@entry=0x7fffae5ff310, options=options@entry=0x7fffae5ff2c0, nRequest=nRequest@entry=0x7fffae5ff2c8, pflin=pflin@entry=0x0) at ../db/dbAccess.c:917
#13 0x00007ffff7d8d820 in dbChannelGet
    (chan=chan@entry=0x7fff8c06b958, type=type@entry=11, pbuffer=pbuffer@entry=0x7fffae5ff310, options=options@entry=0x7fffae5ff2c0, nRequest=nRequest@entry=0x7fffae5ff2c8, pfl=pfl@entry=0x0) at ../db/dbChannel.c:630
#14 0x00007ffff7da6408 in dbChannel_get_count
    (chan=chan@entry=0x7fff8c06b958, buffer_type=<optimized out>, pbuffer=0x7fff8403d3e0, nRequest=nRequest@entry=0x7fffae5ff838, pfl=pfl@entry=0x0) at ../db/db_access.c:644
#15 0x00007ffff7dcef34 in read_reply
    (pArg=pArg@entry=0x7fffae5ff890, dbch=0x7fff8c06b958, eventsRemaining=eventsRemaining@entry=1, pfl=pfl@entry=0x0)
    at ../rsrv/camessage.c:548
This happens when accessing a pv that is on the ADBase  screen. I don't know which one it could be.
Jörn
Am Mittwoch, 19. Juni 2024, 09:56:11 MESZ schrieb Ralph Lange via Tech-talk:
> On Wed, 19 Jun 2024 at 08:53, Jörn Dreyer via Tech-talk <
> tech-talk at aps.anl.gov> wrote:
> > Hi Folks,
> > I encountered a strange problem with EPICS 7.0.8 under Ubuntu 22.04 on
> > x86_64. My IOC crashes when loading ADBase.template:
> > >dbLoadRecords("/home/srsi2d/EPICS/EPICS-7.0.8/modules/src/areaDetector/ADCore/db/ADBase.template",
> > "P=WIZZLERHD:HZDR:,R=asicam3:,PORT=ASICAM3,ADDR=0,TIMEOUT=1")
> > >epicsMutex pthread_mutex_unlock epicsMutexOsdUnlock failed: ERROR
> > Operation not permitted
> > >*** buffer overflow detected ***: terminated
> > The gdb backtrace shows the following:
> > >#8  0x00007ffff7d0c9f9 in strcpy (__src=0x555555636cb0 "0",
> > __dest=0x55555571a288 "")
> > >    at /usr/include/x86_64-linux-gnu/bits/string_fortified.h:79
> > >#9  dbAllocRecord
> > >    (pdbentry=pdbentry@entry=0x555555731348,
> > precordName=precordName@entry=0x555555731288 "cam:SetAcquireBusy") at
> > ../dbStatic/dbStaticRun.c:125
> > >#10 0x00007ffff7d00d13 in dbCreateRecord
> > ../dbStatic/dbStaticLib.c:1441
> > >#11 0x00007ffff7d07e67 in dbRecordHead
> > >    (visible=0, name=0x555555731288 "cam:SetAcquireBusy",
> > recordType=0x5555557312e8 "calcout")
> > >    at ../dbStatic/dbLexRoutines.c:1132
> > >#12 dbRecordHead
> > >    (recordType=0x5555557312e8 "calcout", name=0x555555731288
> > "cam:SetAcquireBusy", visible=0)
> > >    at ../dbStatic/dbLexRoutines.c:1099
> > If I comment out the calcout record it crashes at the next busy record. So
> > it seems that my base installation has a problem, but why and what?
> > The ai, ao, bi, bo and stringin records seem to work fine. The calcout and
> > busy records are defined in my apps dbd file.
> > Any idea what could be wrong?
> Yes.
> This issue was detected last week (see
> https://urldefense.us/v3/__https://github.com/epics-base/epics-base/issues/514__;!!G_uCfscf7eWS!fI4NqAWbBTj6edIyERFKemRmeMC7MdlaLJh4A-4jT3Jr6VurvZR74j0jrYms3MCrhw2OhAACdLLVMZqw_Y7oEsYVOEI$ ).
> Ubuntu 22.04 bumped the "-D_FORTIFY_SOURCE" level to 3, which causes EPICS
> binaries to bail out because of an alleged "buffer overflow". The GCC
> detection engine is getting triggered by specific pointer casting in Base.
> At this point, Michael provided a PR with a workaround. (
> https://urldefense.us/v3/__https://github.com/epics-base/epics-base/pull/517__;!!G_uCfscf7eWS!fI4NqAWbBTj6edIyERFKemRmeMC7MdlaLJh4A-4jT3Jr6VurvZR74j0jrYms3MCrhw2OhAACdLLVMZqw_Y7oZC0EZGc$ )
> Testing this PR would help us verify this change as a quick way out. (Given
> the popularity of Ubuntu, this might justify a bugfix release of Base.)
> Other than that, I have no striking idea how to avoid the issue.
> Cheers,
> ~Ralph
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Abt. FWKX
Tel: +49 351 260 3263
Fax: +49 351 260 123263
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
Tel: +49 (0) 351 260 1234
https://urldefense.us/v3/__http://www.hzdr.de__;!!G_uCfscf7eWS!YHAawezFfG4LL9xJ851paKQlrdWDaVx1pbNkZucTmp1AIaHK4PVKleZvVjia6cI3lRGIRzBRxOZ0dxYgVZuoiDw$
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Re: Strange problem with EPICS areaDetector Ralph Lange via Tech-talk
Prev: Re: Strange problem with EPICS areaDetector Ralph Lange via Tech-talk
Next: Re: AreaDetector Pva problem Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
