1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: [EXTERNAL] IOC connection problem
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 20 Jun 2024 18:27:01 +0200
On Thu, 20 Jun 2024 at 17:04, Hartman, Steven via Tech-talk <tech-talk at aps.anl.gov> wrote:
On Jun 20, 2024, at 10:51 AM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
As I said in a recent post, I don't think there is an easy way to run the firewall on a machine with multiple IOCs, since the subsequent IOCs need random ports to be opened for CA.
While thinking about your error message, I stumbled across this post to tech-talk from Dirk in 2019 . . .
Interesting idea. The IOC would need sufficient privileges to update the firewall rules. Curious if this is used in production.
This approach should be easier nowadays, as
Server exports RSRV_SERVER_PORT
During iocInit(), the environment variable RSRV_SERVER_PORT is set with the TCP port number selected.
starting from EPICS 7.0.7
Cheers,
~Ralph
IOC connection problem Mark Rivers via Tech-talk
Re: [EXTERNAL] IOC connection problem Hartman, Steven via Tech-talk
Re: [EXTERNAL] IOC connection problem Mark Rivers via Tech-talk
Prev: ADGeniCam makeDb.py" error John Dobbins via Tech-talk
Next: RE: ADGeniCam makeDb.py" error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: [EXTERNAL] IOC connection problem Hartman, Steven via Tech-talk
Next: ADGeniCam makeDb.py" error John Dobbins via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
