1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: RE: ADGeniCam makeDb.py" error
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 20 Jun 2024 16:47:54 +0000
Hi John,
I was able to process the xml file you attached into the .template and .adl files with no problem.  I am using the master branch, but the Python scripts are the same as R1-9.
I put the xml file in the xml/ directory and ran the addCamera.sh script:
(base) [epics@corvette ADGenICam]$ ./addCamera.sh PGR_BFS_PGE_13S2M
More than 16 enum entries for PixelFormat mbbi record, discarding additional options.
   If needed, edit the Enumeration tag for PixelFormat to select the 16 you want.
Don't know what to do with Register
More than 16 enum entries for GevSupportedOptionSelector mbbi record, discarding additional options.
   If needed, edit the Enumeration tag for GevSupportedOptionSelector to select the 16 you want.
More than 16 enum entries for ChunkPixelFormat mbbi record, discarding additional options.
   If needed, edit the Enumeration tag for ChunkPixelFormat to select the 16 you want.
There are a few normal warnings, but no errors.
I am using Python 3.7.3.
What version of Python are you using?
Please send the errors when you run addCamera.sh.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of John Dobbins via Tech-talk
Sent: Thursday, June 20, 2024 11:23 AM
To: tech-talk at aps.anl.gov
Subject: ADGeniCam makeDb.py" error
All/Mark,
I used arv-tool to extract an XML file from an older FLIR camera, BFLY-PGE-13S2M.  That XML file makes makeDb.py unhappy and no template is produced.
This is arv-tool-0.10, areaDetector-R3-13, ADGeniCam-R1-9.
I am hoping someone more familiar with the XML can help.  I have attached the XML file as a txt file to try to get through our mail system.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADGeniCam makeDb.py" error John Dobbins via Tech-talk
Prev: Re: [EXTERNAL] IOC connection problem Ralph Lange via Tech-talk
Next: Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: ADGeniCam makeDb.py" error John Dobbins via Tech-talk
Next: Sept. 16-20 EPICS Meeting at Oak Ridge National Laboratory, TN, USA Kasemir, Kay via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
