Thanks Sky, that showed the policyName for the PV and should help me get the policyName displayed in a table or report.
Regards, -ps
You probably want to use the endpoint getPVTypeInfo, for example calling
http://archiver_host_name:17665/mgmt/bpl/getPVTypeInfo?pv=PV1
Will get you json including “policyName”, “datastores”, “samplingPeriod” and “samplingMethod”
The PVTypeInfo is essentially what is stored in the persistence database.
Hope that helps!
Sky
- RE: Archiver Appliance PV by Policy Sky Brewer via Tech-talk
Re: mbbo fields don't match db definitions ??? John Dobbins via Tech-talk
Re: install epics-base: Perl Script Path Interpretation Issue on Windows Johnson, Andrew N. via Tech-talk
<2024>
2025
CSS-Phoebus: Dynamically changing the contents of embedded databrowser Malte Daniel Gotz via Tech-talk
<2024>
2025
ANJ, 11 Sep 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
