1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: CSS-Phoebus: Dynamically changing the contents of embedded databrowser
From: Malte Daniel Gotz via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 26 Jun 2024 15:26:32 +0200
hoping to find some Phoebus experts here to tell me if this is at all possible.
I have a Phoebus display, where a user can check a bunch of checkboxes to activate/deactivate indicators on a drawing of a chamber for a series of pressure, temperature, and flow sensors. Now, I would like to also have an embedded databrowser there to display those PVs that are marked by checked checkboxes.
Is there a way to change, by using embedded scripts or by connecting to a PV, the contents of an embedded databrowser? Either by dynamically adding and removing PVs from it or by hiding/showing PV traces, i.e., accessing the right-click runtime settings of the embedded databrowser?
I can load a different plt-file, by changing that property, but that requires previously created plt-files for all combinations of PVs to be displayed. I would like some other way to manipulate the PVs displayed in an embedded databrowser window at runtime. Does that exist?
Thanks and cheers,
Malte
Dr. Malte Gotz
Accelerator Operation  - Control System Group
(BE-IA-AOT/ACS)
Helmholtz-Zentrum Berlin
Albert-Einstein-Str. 15
12489 Berlin, Germany
Phone: +49 030 8062 15808
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: CSS-Phoebus: Dynamically changing the contents of embedded databrowser Kasemir, Kay via Tech-talk
Prev: RE: Archiver Appliance PV by Policy Sky Brewer via Tech-talk
Next: Re: Driver for Eiger1 with SIMPLON 1.8.0 Rong Huang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: Re: Archiver Appliance PV by Policy Paul Sichta via Tech-talk
Next: Re: CSS-Phoebus: Dynamically changing the contents of embedded databrowser Kasemir, Kay via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
