1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Driver for Eiger1 with SIMPLON 1.8.0
Date: Wed, 26 Jun 2024 09:05:16 -0500
Hi Mark,
Actually there are only 8 "cannot find parameters" when using iocEiger2. Some error messages are repeated.
We have two Eiger detectors, one of Eiger1, and one of Eiger2. Both are using Simplon 1.8.0. I tried to read the 8 "cannot find parameters" from both detectors through Simplon.
Parameters not available in Simplons:         HV_RESET_TIME
Parameters only available in Eiger2 simplon:       THRESHOLD2, THRESHOLD1_ENABLE (threshold/1/mode),  THRESHOLD2_ENABLE (threshold/2/mode)THRESHOLD_DIFF_ENABLE (threshold/difference/mode), EXT_GATE_MODE (config/extg_mode),
Parameters available from simplons of both detectors:        TRIGGER_START_DELAY,    HV_STATE  (status/high_voltage/state)
So, except 2 of them, the others are indeed not available from our Eiger1 simplon interface. Not sure why the Trigger_start_delay and HV_state cannot be read.
Rong
Driver for Eiger1 with SIMPLON 1.8.0 Rong Huang via Tech-talk
RE: Driver for Eiger1 with SIMPLON 1.8.0 Mark Rivers via Tech-talk
Re: Driver for Eiger1 with SIMPLON 1.8.0 Rong Huang via Tech-talk
Re: Driver for Eiger1 with SIMPLON 1.8.0 Mark Rivers via Tech-talk
Prev: CSS-Phoebus: Dynamically changing the contents of embedded databrowser Malte Daniel Gotz via Tech-talk
Next: install epics-base: Perl Script Path Interpretation Issue on Windows Hussein Matar via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: Driver for Eiger1 with SIMPLON 1.8.0 Rong Huang via Tech-talk
Next: Archiver Appliance PV by Policy Paul Sichta via Tech-talk
