Hello,
I am setting up EPICS Base on my Windows 10 machine, but I get a compile
error when I run the Makefile in the EPICS Base directory:
perl -CSD C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base/bin/windows-x64/makeMakefile.pl
O.windows-x64 ../../../..
Can't open perl script "C:/Program": No such file or directory
It seems that my compiler does not interpret the path to the Perl script
correctly, as it only captures the path up to the first space. As a
result, the Perl script cannot be found.
Can you tell me why this is happening and how I can fix the problem?
Which configuration file do I need to edit to correct this?
The complete output of the makefile:
make
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C
./configure install
make[1]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base/configure'
O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
make[2]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base/configure/O.windows-x64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
make[1]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./src
install
Studio/2022/BuildTools/epics-base/src'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./tools
install
Studio/2022/BuildTools/epics-base/src/tools'
O.windows-x64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory 'C:/Program Files (x86)/Microsoft Visual
Studio/2022/BuildTools/epics-base/src/tools/O.windows-x64'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory 'C:/Program Files (x86)/Microsoft Visual
template/base install
Studio/2022/BuildTools/epics-base/src/template/base'
make[2]: *** [../../../configure/RULES_ARCHS:67: O.windows-x64] Error 2
make[1]: *** [../configure/RULES_DIRS:85: template/base.install] Error 2
make: *** [configure/RULES_DIRS:85: src.install] Error 2
Thanks
Hussein
- Re: install epics-base: Perl Script Path Interpretation Issue on Windows Johnson, Andrew N. via Tech-talk
Re: Driver for Eiger1 with SIMPLON 1.8.0 Rong Huang via Tech-talk
Re: mbbo fields don't match db definitions ??? John Dobbins via Tech-talk
<2024>
2025
Re: CSS-Phoebus: Dynamically changing the contents of embedded databrowser Kasemir, Kay via Tech-talk
<2024>
2025
