1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: ADURL failing to open specific URL
From: Marco Filho via Tech-talk <[email protected]>
Date: Wed, 17 Jul 2024 13:17:52 +0000
Extending the discussion, we managed to make it work with curl, so I'm wondering if it would be desirable for ADURL Driver to have an "option" record that can switch from GraphicsMagick to Curl usage and so on...
Sent: 17 July 2024 14:53:09
To: [email protected]
Subject: ADURL failing to open specific URL
Hi all
I'm using ADURL R2-3 with ADSupport R1-10 and ADGraphicsMagick. I'm trying to use it to integrate with Hikivision camera.
The module has succesfully worked with several other URL cameras here, and testing it with a few internal URLs works.
For now, my testing criteria is that if something works like:
curl -o output <TestURL>
Then it would probably work with ADURL. Indeed, this:
caput $(PREFIX)URL1 "https://myUrl"
caput $(PREFIX)Acquire 1
Works fine with a lot of cameras here. However, for this particular hikivision camera I'm getting the error:
dbpf URL1:cam1:URL1 "https://MYURL"
dbpf URL1:cam1:Acquire 1
DBF_STRING:         "Acquire"
2024/07/17 14:26:11.700 URLDriver:readImage: error reading URL="" Unable to access configuration file (delegates.mgk) reported by ../supportApp/GraphicsMagickSrc/magick/blob.c:1971 (GetConfigureBlob)
Curiously, I tried it with a different url which I got from any image in google images:
curl -o output https://tmssl.akamaized.net/images/foto/galerie/neymar-brazil-2023-1694521247-116480.jpg
gets me a nice image of Neymar. However:
ics-ups-ioc-dev-344581 > dbpf $(PREFIX)cam1:Acquire 1
ics-ups-ioc-dev-344581 > 2024/07/17 14:29:57.383 URLDriver:readImage: error reading URL="" Unable to open file (//tmssl.akamaized.net/images/foto/galerie/neymar-brazil-2023-1694521247-116480.jpg) reported by ../supportApp/GraphicsMagickSrc/magick/constitute.c:1540 (ReadImage)
No smiling neymar for my EPICS viewer :(
Am I doing something wrong?
What I was able to find out until now:
Inside the driver, the line that generates the exception is URLDriver.cpp:82 image.read(URLString) because it immediately gets out of the try loop and catches an exception.
It calls Image::read(), which calls Image *ReadImage in constitute.c:1449
> From now on I can't quite understand what is happening... I know the condition in
if ((*image_info->filename == '@') && (!IsAccessibleNoLogging(image_info->filename)))
return(ReadImages(image_info,exception));
Is not evaluating to True but I don't think it should anyway... I still didn't find anything that seems like the method that should actually read the image from the URL.
Thanks for any insights.
ADURL failing to open specific URL Marco Filho via Tech-talk
Prev: ADURL failing to open specific URL Marco Filho via Tech-talk
Next: Re: Use PV value as a macro definition when opening a display William F Badgett Jr via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: Re: ADURL failing to open specific URL Ralph Lange via Tech-talk
