1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: field(OUT, "Bdeta PP") worked only the first time
From: "Tran, Phi Dung via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 25 Jul 2024 18:25:41 +0000
My field(OUT, "Bdelta PP ")  worked only the first time.
Subsequently, after that dbpf C2Bend did not process
the OUT field or Bdelta did not process even though it was in
the dbpr C2Bend 10.
Please advice.
Alex
Here is a snippet of my records,
record(motor,"$(C2Bend)"){
    field(DTYP, "Soft Channel")
    field(PREC, "4")
    field(SCAN, "Passive")
    field(TPRO,1)
record(calc, "Bdelta") {
    field(INPA, "$(C2Bend)")
    field(INPB, "$(C2Bend).LVAL") #Previous VAL
    field(CALC, "A-B")
    field(PACT, "0")
    field(FLNK, "fanout2")
    field(TPRO,1)
Here are my outputs after st.cmd.
epics> dbpf C2Bend 5
_main_: dbProcess of 'C2Bend'
_main_: dbProcess of 'Bdelta'
_main_: dbProcess of 'fanout2'
_main_: dbProcess of 'Bbend1_calc'
_main_: dbProcess of Active 'CBend1' with RPRO=1
_main_: dbProcess of 'Bbend2_calc'
_main_: dbProcess of Active 'CBend2' with RPRO=1
DBF_DOUBLE:         5
epics> dbpf C2Bend 266
DBF_DOUBLE:         266
epics> dbgf Bdelta.PACT
DBF_UCHAR:          0 = 0x0
epics> dbgf Bdelta.DISP
DBF_UCHAR:          0 = 0x0
epics> dbpf Bdelta.PROC 1
DBF_UCHAR:          1 = 0x1
Prev: Re: IOC with Normative Types Michael Davidsaver via Tech-talk
Next: Errors using lvPortDriver Ramirez-Morales, Jacob J (CONTR) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
