1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: tune CSS Phoebus's memory usage
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "Xiao, Lingran" <[email protected]>
Date: Mon, 29 Jul 2024 13:10:50 -0700
JVM memory usage is a big topic...
The are __many__ hooks.  Some which may be relevant are
Min/MaxHeapFreeRatio and ShrinkHeapInSteps options.
eg. my current settings of phoebus where I hope to persuade a more
or less idle JVM to more aggressively release memory back to the
system.
 -XX:MinHeapSize=128m \
 -XX:MaxHeapSize=2g \
 -XX:InitialHeapSize=1g \
 -XX:MaxHeapFreeRatio=10 \
 -XX:MinHeapFreeRatio=5 \
 -XX:-ShrinkHeapInSteps \
 -XX:NativeMemoryTracking=detail \
These values are largely taken from examples I found of tuning java
for "embedded" or "memory constrained" targets.
https://urldefense.us/v3/__https://docs.oracle.com/en/java/javase/11/gctuning/factors-affecting-garbage-collection-performance.html__;!!G_uCfscf7eWS!ahLPSop-9LD061W5kvdbPA8dXGJtKpt5ZPEVh5Eb840RChNtxJwLEvssj80Omtc6FxQWZEUmnEjHAastIo-0_wZIvA$ https://urldefense.us/v3/__https://bugs.openjdk.org/browse/JDK-8146436__;!!G_uCfscf7eWS!ahLPSop-9LD061W5kvdbPA8dXGJtKpt5ZPEVh5Eb840RChNtxJwLEvssj80Omtc6FxQWZEUmnEjHAastIo-YHplDAg$
On 7/29/24 11:21, Kasemir, Kay via Tech-talk wrote:
I’d be concerned about memory leaks, but not memory usage in general.
Java Virtual Machine Memory
CS-Studio/Phoebus is a plain Java application, with memory managed by the JVM.
See also https://urldefense.us/v3/__https://developers.redhat.com/articles/2021/09/09/how-jvm-uses-and-allocates-memory__;!!G_uCfscf7eWS!ahLPSop-9LD061W5kvdbPA8dXGJtKpt5ZPEVh5Eb840RChNtxJwLEvssj80Omtc6FxQWZEUmnEjHAastIo_1btiQEg$  <https://urldefense.us/v3/__https://developers.redhat.com/articles/2021/09/09/how-jvm-uses-and-allocates-memory__;!!G_uCfscf7eWS!eMPX4b_BmFqjCFGXz0Lw2r6T_s-9oURGcJkqEWUtMmUZ5sujgZ8JUIYfxChOJs9xFUdEFqYo6FvgxP7T7vNd4pE$>
When you launch the applications, the JVM option `-Xmx` sets the maximum amount of memory that the JVM will use, and `-Xms` sets the initial amount.
For example,
export JDK_JAVA_OPTIONS="-Xms500M -Xmx2G"
java -jar product.jar
will start the JVM will 500MB of memory, and it will allocate up to 2GB.
A tool like VisualVM (free, https://urldefense.us/v3/__https://visualvm.github.io__;!!G_uCfscf7eWS!ahLPSop-9LD061W5kvdbPA8dXGJtKpt5ZPEVh5Eb840RChNtxJwLEvssj80Omtc6FxQWZEUmnEjHAastIo89zayEjQ$  <https://urldefense.us/v3/__https://visualvm.github.io__;!!G_uCfscf7eWS!eMPX4b_BmFqjCFGXz0Lw2r6T_s-9oURGcJkqEWUtMmUZ5sujgZ8JUIYfxChOJs9xFUdEFqYo6FvgxP7TY0pTgm4$>) or JProfiler (very good but not free, https://urldefense.us/v3/__https://www.ej-technologies.com/products/jprofiler/overview.html__;!!G_uCfscf7eWS!ahLPSop-9LD061W5kvdbPA8dXGJtKpt5ZPEVh5Eb840RChNtxJwLEvssj80Omtc6FxQWZEUmnEjHAastIo_LXqREKw$  <https://urldefense.us/v3/__https://www.ej-technologies.com/products/jprofiler/overview.html__;!!G_uCfscf7eWS!eMPX4b_BmFqjCFGXz0Lw2r6T_s-9oURGcJkqEWUtMmUZ5sujgZ8JUIYfxChOJs9xFUdEFqYo6FvgxP7TRoDJyCM$>) can be used to track memory usage over time.
What you should see is a sawtooth-type pattern where the application uses more and more memory, maybe up to the `-Xmx` limit, then frees it.
When you open several displays, the sawtooth pattern may ramp up more rapidly, and when you then close those displays, it should free memory and return to a slower/longer sawtooth pattern. If you find a scenario where the memory keeps increasing until running out of memory, you may have spotted a memory leak that should should report, ideally with a reproducible recipe.
Linux Memory
It can be confusing to compare memory usage as reported by the JVM with the memory usage reported by the Linux OS.
Especially the "VIRT" virtual memory indicated in for example `top` may appear huge, but that tends to have no
practical significance, see for example https://urldefense.us/v3/__https://stackoverflow.com/questions/561245/virtual-memory-usage-from-java-under-linux-too-much-memory-used__;!!G_uCfscf7eWS!ahLPSop-9LD061W5kvdbPA8dXGJtKpt5ZPEVh5Eb840RChNtxJwLEvssj80Omtc6FxQWZEUmnEjHAastIo8i7Vg-4w$  <https://urldefense.us/v3/__https://stackoverflow.com/questions/561245/virtual-memory-usage-from-java-under-linux-too-much-memory-used__;!!G_uCfscf7eWS!eMPX4b_BmFqjCFGXz0Lw2r6T_s-9oURGcJkqEWUtMmUZ5sujgZ8JUIYfxChOJs9xFUdEFqYo6FvgxP7TXiL_1Bc$>, which also points to related discussions of the glibc `MALLOC_ARENA_MAX` setting.
*From: *Tech-talk <[email protected]> on behalf of Xiao, Lingran via Tech-talk <[email protected]>
*Date: *Monday, July 29, 2024 at 1:51 PM
*To: *[email protected] <[email protected]>
*Subject: *[EXTERNAL] tune CSS Phoebus's memory usage
Hi all,
We're concerned about CSS Phoebus's high memory usages. I was wondering do you have the same concerns. And did you take any actions to minimize the memory usages while maintaining Phoebus's performance? Any inputs are welcome.
Thanks a lot,
Lingran
tune CSS Phoebus's memory usage Xiao, Lingran via Tech-talk
Re: tune CSS Phoebus's memory usage Kasemir, Kay via Tech-talk
Prev: Re: tune CSS Phoebus's memory usage Kasemir, Kay via Tech-talk
Next: Registration deadline for Sept. 16-20 EPICS Meeting at ORNL, USA Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
