1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Install issues for labCA (channel access interface for matlab)
From: Rajan Mistry - STFC UKRI via Tech-talk <[email protected]>
Date: Fri, 2 Aug 2024 13:29:18 +0000
Hello,
I have a windows PC and am trying to install the channel access interface for MATLAB, known as labca:
LabCA - EPICS/Channel Access Interface for Scilab and Matlab | epics-labca (till-s.github.io)
GitHub - till-s/epics-labca: EPICS Channel-Access Interface/Wrapper for Matlab and Scilab.
I am relatively new to EPICs, but have successfully installed EPICS to the location:
C:\Users\fhr83689\base-R7.0.4.1\bin\windows-x64
Commands such as ‘softioc’ will start EPICS, so I am confident that I have installed EPICS correctly.
The following system and user variables paths are defined , and are saved in my PATH environment variables (both system and user):
EPICS_BASE=“C:\Users\fhr83689\base-R7.0.4.1\”
EPICS_HOST_ARCH=”windows-x64”
%EPICS_BASE%\bin\%EPICS_HOST_ARCH%\
%EPICS_BASE%
I have cloned the tag 3.8.1 from the labCA repo into my downloads folder and then ran the make command to install it. However, it is not successfully installed and I get the following error messages (pasted at the end of this post).
Please can someone help me figure out what the issue is and how I can successfully install labCA ?
Raj
C:\Users\fhr83689\Downloads\epics-labca>make
The system cannot find the path specified.
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./configure install
make[1]: Entering directory 'C:/Users/fhr83689/Downloads/epics-labca/configure'
perl -CSD C:/Users/fhr83689/base-R7.0.4.1/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
make[2]: Entering directory 'C:/Users/fhr83689/Downloads/epics-labca/configure/O.windows-x64'
perl -CSD C:/Users/fhr83689/base-R7.0.4.1/bin/windows-x64/convertRelease.pl checkRelease
process_begin: CreateProcess(NULL, C:/Program Files/MATLAB/R2023a /bin/mexext.bat, ...) failed.
../../configure/RULES:10: pipe: No such file or directory
echo MEXEXT=.dll >>MATLAB_CONFIG_INCLUDE
make[2]: Leaving directory 'C:/Users/fhr83689/Downloads/epics-labca/configure/O.windows-x64'
make[1]: Leaving directory 'C:/Users/fhr83689/Downloads/epics-labca/configure'
C:/ProgramData/chocolatey/lib/make/tools/install/bin/make.exe -C ./ezca install
make[1]: Entering directory 'C:/Users/fhr83689/Downloads/epics-labca/ezca'
make[2]: Entering directory 'C:/Users/fhr83689/Downloads/epics-labca/ezca/O.windows-x64'
perl -CSD C:/Users/fhr83689/base-R7.0.4.1/bin/windows-x64/mkmf.pl  -m ezca.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include          -IC:/Users/fhr83689/base-R7.0.4.1/include/compiler/msvc -IC:/Users/fhr83689/base-R7.0.4.1/include/os/WIN32 -IC:/Users/fhr83689/base-R7.0.4.1/include                 ezca.obj ../ezca.c
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -GL -Oy-   -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include          -IC:/Users/fhr83689/base-R7.0.4.1/include/compiler/msvc -IC:/Users/fhr83689/base-R7.0.4.1/include/os/WIN32 -IC:/Users/fhr83689/base-R7.0.4.1/include                 -c ../ezca.c
process_begin: CreateProcess(NULL, cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Users/fhr83689/base-R7.0.4.1/include/compiler/msvc -IC:/Users/fhr83689/base-R7.0.4.1/include/os/WIN32 -IC:/Users/fhr83689/base-R7.0.4.1/include -c ../ezca.c, ...) failed.
make (e=2): The system cannot find the file specified.
make[2]: *** [C:/Users/fhr83689/base-R7.0.4.1/configure/RULES_BUILD:241: ezca.obj] Error 2
make[2]: Leaving directory 'C:/Users/fhr83689/Downloads/epics-labca/ezca/O.windows-x64'
make[1]: *** [C:/Users/fhr83689/base-R7.0.4.1/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[1]: Leaving directory 'C:/Users/fhr83689/Downloads/epics-labca/ezca'
make: *** [C:/Users/fhr83689/base-R7.0.4.1/configure/RULES_DIRS:85: ezca.install] Error 2
Rajan Mistry
Laser Scientist (CALTA)
Central Laser Facility
R109 1.26
STFC Rutherford Appleton Laboratory
Harwell Campus, Didcot, OX11 0QX, UK
[email protected]
Tel. +44 1235 394308
UKRI_STFC
RE: Install issues for labCA (channel access interface for matlab) Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Accessing NTAttribute of an NTNDArray from Phoebus? Feister, Scott via Tech-talk
Next: Motor Drivers for Applied Motion Products (Ethernet/IP)? Feister, Scott via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: RE: Install issues for labCA (channel access interface for matlab) Freddie Akeroyd - STFC UKRI via Tech-talk
