Hello all,
Currently, we are using the mvme6100 model. However, we heard that it will be discontinued. We would like to secure an additional 5500 or 3300 model for maintenance. However, before purchasing, we would like to make sure that the mvme5500 we have is compatible with vxworks6.9 os.
I'm trying to copy this link from Tech Talk.
https://epics.anl.gov/tech-talk/2004/msg00847.php
As for the jumper setting, I set the jumper j8 to flash1 as told here.
Copyright Motorola Inc. 1999-2003, All Rights Reserved
MOTLoad RTOS Version 2.0, PAL Version 1.1 RM02
Tue Jul 1 16:34:30 MST 2003
Warning: Global Environment Variable Area is uninitialized, use gevInit.
MPU-Int Clock Speed =1000MHz
MPU-Ext Clock Speed =133MHz
MPU-Number/Type = 0/MPC7455
MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
MPU-Ext Cache(L3) = 2MB, Enabled, 200MHz, L3CR=0xDF826000
Reset/Boot Vector =Flash1
Local Memory Found =20000000 (&536870912)
User Download Buffer =005C3000:007C2FFF
MVME5500> netShow
Interface EAddress Status Speed Duplex
/dev/enet0 0001AF0B1BEC Up 100MBS Full
/dev/enet1 0001AF0B1BED Downp Unknown Unknown
MVME5500> gevEdit mot-/dev/enet0-cipa
