1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: RE: MVME 5500 How to flash the VxWorks bootrom?
From: whitetiger1123 via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 30 Aug 2024 16:48:01 +0900
I solved this error and try to set client, server, gateway, subnet ip address.
It was because of Warning: Global Environment Variable Area is uninitialized, use gevInit.
I did it gevInit and pressed Y, it changed.
Btw theres no way how to change subnet IP address mask.
How can I know the command?
I already changed cliend as cipa, server as sipa, gateway as gipa.
Thank you always for your help and advice.
Best and Regards,
Baeg
보낸 사람: whitetiger1123
보낸 날짜: 2024 8 30일 금요일 오후 3:46
받는 사람: tech-talk at aps.anl.gov
제목: MVME 5500 How to flash the VxWorks bootrom?
Hello all,
Currently, we are using the mvme6100 model. However, we heard that it will be discontinued. We would like to secure an additional 5500 or 3300 model for maintenance. However, before purchasing, we would like to make sure that the mvme5500 we have is compatible with vxworks6.9 os.
I'm trying to copy this link from Tech Talk.
https://epics.anl.gov/tech-talk/2004/msg00847.php
As for the jumper setting, I set the jumper j8 to flash1 as told here.
Copyright Motorola Inc. 1999-2003, All Rights Reserved
MOTLoad RTOS Version 2.0,  PAL Version 1.1 RM02
Tue Jul 1 16:34:30 MST 2003
MPU-Int Clock Speed =1000MHz
MPU-Ext Clock Speed =133MHz
MPU-Number/Type = 0/MPC7455
MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
MPU-Ext Cache(L3) =   2MB, Enabled, 200MHz, L3CR=0xDF826000
Reset/Boot Vector    =Flash1
Local Memory Found   =20000000 (&536870912)
User Download Buffer =005C3000:007C2FFF
MVME5500>  netShow
Interface            EAddress               Status      Speed         Duplex
/dev/enet0       0001AF0B1BEC                 Up        100MBS          Full
/dev/enet1       0001AF0B1BED                Downp       Unknown      Unknown
MVME5500> gevEdit mot-/dev/enet0-cipa
PReP NVRAM header test failed
I cant do anything because of this red line error message.
Even if I do,
MVME5500> gevEdit mot-script-boot
Can you give me any advice?
I really appreciate it.
Best & Regards,
Beag.
Re: MVME 5500 How to flash the VxWorks bootrom? Maren Purves via Tech-talk
Re: MVME 5500 How to flash the VxWorks bootrom? Wang, Lin via Tech-talk
MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
Prev: Re: MVME 5500 How to flash the VxWorks bootrom? Maren Purves via Tech-talk
Next: Re: MVME 5500 How to flash the VxWorks bootrom? Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
