1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: MVME 5500 How to flash the VxWorks bootrom?
From: Maren Purves via Tech-talk <[email protected]>
To: whitetiger1123 <[email protected]>
Date: Thu, 29 Aug 2024 23:00:18 -1000
If the interface hasn't  changed since VxWorks 5.5, "bootChange"?
Maren
On Thu, Aug 29, 2024 at 9:48 PM whitetiger1123 via Tech-talk
<[email protected]> wrote:
> I solved this error and try to set client, server, gateway, subnet ip address.
> It was because of “Warning: Global Environment Variable Area is uninitialized, use gevInit.”
> I did it gevInit and pressed Y, it changed.
> Btw there’s no way how to change subnet IP address mask.
> How can I know the command?
> I already changed cliend as cipa, server as sipa, gateway as gipa.
> Thank you always for your help and advice.
> Best and Regards,
> Baeg
> 보낸 사람: whitetiger1123
> 보낸 날짜: 2024년 8월 30일 금요일 오후 3:46
> 받는 사람: [email protected]
> 제목: MVME 5500 How to flash the VxWorks bootrom?
> Hello all,
> Currently, we are using the mvme6100 model. However, we heard that it will be discontinued. We would like to secure an additional 5500 or 3300 model for maintenance. However, before purchasing, we would like to make sure that the mvme5500 we have is compatible with vxworks6.9 os.
> I'm trying to copy this link from Tech Talk.
> https://urldefense.us/v3/__https://epics.anl.gov/tech-talk/2004/msg00847.php__;!!G_uCfscf7eWS!d2flDKDaROrKKthpbgComyKjcAhrbxUNGDJ-zig_4T2g0s1YrJdkhef2zbY0NTihVczHo9zm028kR8Xclvbopuj9D3QM$
> As for the jumper setting, I set the jumper j8 to flash1 as told here.
> Copyright Motorola Inc. 1999-2003, All Rights Reserved
> MOTLoad RTOS Version 2.0,  PAL Version 1.1 RM02
> Tue Jul 1 16:34:30 MST 2003
> MPU-Int Clock Speed =1000MHz
> MPU-Ext Clock Speed =133MHz
> MPU-Number/Type = 0/MPC7455
> MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
> MPU-Ext Cache(L3) =   2MB, Enabled, 200MHz, L3CR=0xDF826000
> Reset/Boot Vector    =Flash1
> Local Memory Found   =20000000 (&536870912)
> User Download Buffer =005C3000:007C2FFF
> MVME5500>  netShow
> Interface            EAddress               Status      Speed         Duplex
> /dev/enet0       0001AF0B1BEC                 Up        100MBS          Full
> /dev/enet1       0001AF0B1BED                Downp       Unknown      Unknown
> MVME5500> gevEdit mot-/dev/enet0-cipa
> PReP NVRAM header test failed
> I can’t do anything because of this red line error message.
> Even if I do,
> MVME5500> gevEdit mot-script-boot
> Can you give me any advice?
> I really appreciate it.
> Best & Regards,
> Beag.
MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
RE: MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
Prev: RE: MVME 5500 How to flash the VxWorks bootrom? whitetiger1123 via Tech-talk
Next: Re: MVME 5500 How to flash the VxWorks bootrom? Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
