1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: MVME5500 with vxworks6.9
From: whitetiger1123 via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 2 Sep 2024 16:10:53 +0900
Hello, all.
I'm also struggling with searching the internet and checking the manual, so I'm leaving a question on tech talk.
MVME5500 model completed vxworks system boot. Jumper chose J8 flash0 and vxworks system booted.
But I have a question here. It becomes a vxworks system boot and there are commands for cpu, version, and bsp. Please see below.
VxWorks System Boot
Copyright 1984-2002 Wind River Systems, Inc.
CPU: Motorola MVME5500-0163 - MPC 7455
Version: VxWorks5.5
BSP version: 1.2/1
Creation date: Apr 27 2004, 17:31:50
In this command, does the version guide the vxworks version supported by the mvme5500, or does it show the vxworks version that I previously booted?
I set the st.cmd of vxworks 6.9 the same as the mvme6100 model.
[VxWorks Boot]: p
boot device : geisc
unit number : 0
processor number : 0
host name : host
file name : /usr/local/epics_motor/vxWorks
inet on ethernet (e) : 10.4.134.17:fffff000
inet on backplane (b): 0
host inet (h) : 10.4.133.179
gateway inet (g) : 10.4.128.1
user (u) : daqadmin
ftp password (pw) : pal#2016
flags (f) : 0x0
target name (tn) : test
startup script (s) : host:/usr/local/epics_motor/synApps_5_8/support/motor-6-9/iocBoot/SX_EH_motor/st.cmd
And I tried to run it, but it didn't boot and I kept getting the message [Vxworks Boot]:.
[VxWorks Boot]: @
[VxWorks Boot]:
Does the mvme5500 model only support version 5.5 of vxworks? If 6.9 version is available, should I flash the bootrom again?
I really appreciate of your help.
Best Regards,
Baeg
Re: MVME5500 with vxworks6.9 Hao, Hao via Tech-talk
Prev: Re: Upgrading EPICS base from 3.15.6 to 7.0.x Mark Rivers via Tech-talk
Next: Build PCAS within the EPICS base LONG FENG via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: Re: MVME5500 with vxworks6.9 Hao, Hao via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
