1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Adding additional fields to be archived in "policies.py"
From: Timo Korhonen via Tech-talk <[email protected]>
To: Gerrit Kühn <[email protected]>
Cc: Michael Davidsaver via Tech-talk <[email protected]>
Date: Fri, 6 Sep 2024 09:18:26 +0000
Correction:
I should have written alarm _severity_ below (NO_ALARM, MINOR, MAJOR and INVALID).
Alarm status is the other field that gives you more detailed information.
Sorry for the spam.
Timo
On 2024-09-06, 11:09, "Tech-talk on behalf of Timo Korhonen via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
The data validity is included in the alarm concept by having the alarm status INVALID. See here for more details:
https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/process-database/EPICS_Process_Database_Concepts.html <https://urldefense.us/v3/__https://docs.epics-controls.org/en/latest/process-database/EPICS_Process_Database_Concepts.html>*alarm-specification__;Iw!!G_uCfscf7eWS!ZdkeLEEiCbQ2_BdTJHku1FLAjrRImHdLJ45jYo9zmRX9sxEibTm6fEj-iZbEd3A4mWCxl79-PDc4fIg1yyFxFgRvWJfL$
Invalid is the "highest" alarm status which tells that the data is not to be trusted, typically if there is a problem in communicating with the device.
This does not rely on HIGH, HIHI, etc., but is shown in the severity field in the archived data.
I think that should do what you need - as far as I understand correctly. I am not familiar with the archiver datasource plugin though.
Timo
On 2024-09-06, 10:47, "Gerrit Kühn" <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
Am Fri, 6 Sep 2024 07:47:19 +0000
schrieb Timo Korhonen <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>>:
Hello Timo,
> You see the "severity" and "status" values, which in this case were both
> 0.
> You then of course need the additional metadata (HIHI,HIGH,LOW,LOLO) to
> tell what the alarm actually means. But this metadata is not saved with
> each sample.
> I hope this helps.
Partly. :)
We have a different scenario here: We use grafana with the archiver
datasource plugin
(https://urldefense.us/v3/__https://github.com/sasaki77/archiverappliance-datasource/__;!!G_uCfscf7eWS!ZdkeLEEiCbQ2_BdTJHku1FLAjrRImHdLJ45jYo9zmRX9sxEibTm6fEj-iZbEd3A4mWCxl79-PDc4fIg1yyFxFoSoZLBY$ <https://urldefense.us/v3/__https://github.com/sasaki77/archiverappliance-datasource/__;!!G_uCfscf7eWS!ZdkeLEEiCbQ2_BdTJHku1FLAjrRImHdLJ45jYo9zmRX9sxEibTm6fEj-iZbEd3A4mWCxl79-PDc4fIg1yyFxFoSoZLBY$> <https://urldefense.us/v3/__https://github.com/sasaki77/archiverappliance-datasource/__;!!G_uCfscf7eWS!ZdkeLEEiCbQ2_BdTJHku1FLAjrRImHdLJ45jYo9zmRX9sxEibTm6fEj-iZbEd3A4mWCxl79-PDc4fIg1yyFxFoSoZLBY$ <https://urldefense.us/v3/__https://github.com/sasaki77/archiverappliance-datasource/__;!!G_uCfscf7eWS!ZdkeLEEiCbQ2_BdTJHku1FLAjrRImHdLJ45jYo9zmRX9sxEibTm6fEj-iZbEd3A4mWCxl79-PDc4fIg1yyFxFoSoZLBY$> >) to build
dashboards from archiver data. We would like to display some kind of
additional information to show if the data is actually valid. So the first
idea was to use .STAT for this (which is not available by default). Is
there any other way to access this information via the plugin?
The IOC gets its data via network using streamdevice, so the reason for an
error would rather be a timeout or communication error which would
probably not show up in available fields like HIHI,HIGH,LOW,LOLO.
cu
Gerrit
Adding additional fields to be archived in "policies.py" Windsor Tanner via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Michael Davidsaver
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn
Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Prev: Re: Adding additional fields to be archived in "policies.py" Timo Korhonen via Tech-talk
Next: Re: Adding additional fields to be archived in "policies.py" Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
