1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: HTTP PUT Request - StreamDevice
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 11 Sep 2024 14:51:29 +0000
Hello Kyle,
For testing, I have started a fake server with:
ncat -l -p 8080
And have sent the command to it:
curl -X PUT -d '"New-Hostname"' \
https://urldefense.us/v3/__http://fakeserver:8080/ioc/net/hostname/value.json__;!!G_uCfscf7eWS!fPjuCGLT1g3xZP4zVp3oduVQRQQ66fh9LRXE72FJ7JbyP5_eMGtWZZb-uDS34mbST73dkjiuxG03esEcZ6ZZ1FwjRw$
What I see in ncat is:
PUT /ioc/net/hostname/value.json HTTP/1.1
Host: fakeserver:8080
User-Agent: curl/7.61.1
Accept: */*
Content-Length: 14
Content-Type: application/x-www-form-urlencoded
"New-Hostname"[no newline!]
I guess some lines may be optional, but one thing is important:
There is an empty line between header and content. Be aware that your
OutTerminator is only added at the end or out commands (where curl did not
bother to add any terminator).
Thus I suggest you either add the empty line manually:
set_host{
    out 'PUT /io/net/hostname/value.json HTTP/1.1\r\n\r\n"New-Hostname"';
Or alternatively use 2 out commands, each will be terminated with CR LF CR LF.
set_host{    out 'PUT /io/net/hostname/value.json HTTP/1.1';
             out '"New-Hostname"';}
If that is still not sufficient, try to add some of the other header lines, but
have an empty line only directly before the content.
Dirk
On Wed, 2024-09-11 at 14:26 +0000, Zimoch Dirk via Tech-talk wrote:
> Hi Kyle,
> I will have a look...
> Dirk
> On Wed, 2024-09-11 at 14:19 +0000, Kyle Hesse via Tech-talk wrote:
> > Hello,
> > I'm working with a Pyramid FX4 Device. I'd like to use HTTP requests to communicate using StreamDevice. I'm having success using GETs, however I'm running into issues with the PUTs.
> > The programmer manual states to do the following:
> > PUT /io/net/hostname.json HTTP/1.1
> > "New-Hostname"
> > Below I've listed my configuration as well as examples for the GET and PUT requests for getting and setting the hostname.
> > Any help to properly form the HTTP PUT request would be greatly appreciated.
> > Thanks,
> > Kyle
> > Configuration:
> > drvAsynIPPortConfigure("fx4", "129.57.203.137:80 HTTP", 0, 0, 0)
> > OutTerminator = CR LF CR LF;
> > PUT Request Example (Unsuccessful):
> > set_host{
> >     out 'PUT /io/net/hostname/value.json HTTP/1.1 "New-Hostname"';
> > Get Request (Successful):
> > hostname {
> >         out "GET /io/net/hostname/value.json HTTP/1.1";
> >                in "%*182c%[_a-zA-Z0-9]%*2c";
> > PS
> > I am able to use curl from command line to successfully set the hostname.
> > curl -X PUT -d '"New-Hostname"' https://urldefense.us/v3/__http://129.57.203.137/io/net/hostname/value.json__;!!G_uCfscf7eWS!f01ayFSJNsXqAAqGmOKGPXH4SuSPR_8UAlf8IXiWd-JuQtDWoFGjoDqT-FV3qjx0n8nkLhDvsD1Dx35nhsUmiKf7Ug$
Re: HTTP PUT Request - StreamDevice Kyle Hesse via Tech-talk
Re: HTTP PUT Request - StreamDevice Zimoch Dirk via Tech-talk
Prev: Re: HTTP PUT Request - StreamDevice Zimoch Dirk via Tech-talk
Next: Re: HTTP PUT Request - StreamDevice Kyle Hesse via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
