1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: archive appliance some PVs no data
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Tue, 24 Sep 2024 06:12:06 +0000
Hello all
I would like to discuss something similar related to AA, would it make sense if it has an option to take its own timestamp instead of CA’s timestamp? The same thing as caget/camonitor tools do? If the answer is no, why is that? We faced the same issue with some device that could not sync with our NTP servers. After many troubleshooting attempts I decided to create “buffer” PVs (calc records) where they just read the value of any PV as it is.
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Shen, Guobao via Tech-talk
Sent: Tuesday, September 24, 2024 3:44 AM
To: Huang, Rong <[email protected]>; Michael Davidsaver <[email protected]>
Cc: [email protected]
Subject: Re: archive appliance some PVs no data
Rong,
From the Archiver Appliance’s website, it has statistic data about the PV connections, drops, and etc.
Regarding the timestamp, beyond your timestamp, I guess that all PVs inside your IOC got processed?
From our deployment at APS accelerator side, we did occasionally see some data point drops.
But over, it’s pretty healthy.
Guobao
From: Tech-talk <[email protected]> on behalf of Rong Huang via Tech-talk <[email protected]>
Date: Monday, September 23, 2024 at 6:23
 PM
To: Michael Davidsaver <[email protected]>
Cc: [email protected] <[email protected]>
Hi Michael,
Thank you very much for your reply.
I searched for keyword "dropped" in all tomcat instance directories where each log directory locates, I find nothing:
archiver@strawberry:~/epics/archive$ grep -r "dropped" engine/logs/
archiver@strawberry:~/epics/archive$ grep -r "dropped" etl/logs/
archiver@strawberry:~/epics/archive$ grep -r "dropped" mgmt/logs/
archiver@strawberry:~/epics/archive$ grep -r "dropped" retrieval/logs/
 You are right that on the detail page, the problemed PV's "how many events so far" is 0.
Paul Sichta from PPPL emailed me and mentioned the possibility of a wrong PV timestamp. I find out our troubled PVs have the timestamp of year 1990, and I will discuss with our IT staff to find out what changed to our IOC booting host PC.
Our IOC cmd file uses `putenv ("EPICS_TS_NTP_INET=10.1.0.3")` to sync time with the PC.
Thanks a lot,
Rong
On Mon, Sep 23, 2024 at 12:50 PM Michael Davidsaver <[email protected]> wrote:
On 9/23/24 12:20, Rong Huang via Tech-talk wrote:
> Hello,
> I installed Archiver Appliance last year while APS was down. To learn how to use it, I started archiving some PVs, and paused them. I "resumed" the archiving now while APS is back, but some PVs can be archived, some PVs cannot.
Some general AA troubleshooting advice...
I would suggest looking at the "error" reports pages,
paying special attention to those with names beginning
with "PVs by dropped ...".
Also, look on the details page for one of the PVs in question.
eg. look for the "How many events so far?" line.  Refresh a
few times to see that it increments when that PV should update.
Also look for "How many events lost totally so far?" and see
that it is zero, or at least not incrementing.
> I use http://strawberry.ls-cat.org:17665/mgmt/ui/index.html <https://urldefense.us/v3/__http://strawberry.ls-cat.org:17665/mgmt/ui/index.html__;!!G_uCfscf7eWS!dGt06d4Y35r21tzRJQ1P4MfKQL9FjIyz9ZfpC9EqT_x-zgfhGmPeWFfshx886REUI6bsf-LGb559zQ0dOJG_bOkZ$> to Achive/Pause/Resume archiving.
> I use http://strawberry.ls-cat.org:17668/retrieval/ui/viewer/archViewer.html <https://urldefense.us/v3/__http://strawberry.ls-cat.org:17668/retrieval/ui/viewer/archViewer.html__;!!G_uCfscf7eWS!dGt06d4Y35r21tzRJQ1P4MfKQL9FjIyz9ZfpC9EqT_x-zgfhGmPeWFfshx886REUI6bsf-LGb559zQ0dODFD8Xz_$> to view/retrive data.
> The problem, using "21:C1:MO:E:ActPos" as an example, the archViewer website showing one value straight line, "113" Kev, for any display time ranges. "113" comes from the mono E reading when I started archiver appliance last year but not the current E reading.
> I deleted the PV "21:C1:MO:E:ActPos" and its data from archiver appliance, re-entered the PV and started its archiving, the mgmt page showed it "Being archived", "appliance0", "Connected? true", "Sampling period: 10.0".
> archViewer web page shows a flat line of "0" for any time range.
> There is no data file of this PV saved in /arch/sts/ArchiverStore/21. (Even there is no subdirectory of "C1" in /arch/sts/ArchiverStore/21 after I manually removed it and deleted all 21:C1:* PVs)
> Restarting archiving appliance (sampleStart.sh stop & sampleStart.sh start) does not help.
> But some PVs can be archived after "resume" (some of them might have noise, therefore the values were varying all the time in the past).
> I am using apache-tomcat-9.0.86. mysql 8.0.37-0ubuntu0.22.04.3, I installed Archinver Appliance using single_mechine_install.sh.
> Thanks a lot!
> Rong
Re: archive appliance some PVs no data Michael Davidsaver via Tech-talk
archive appliance some PVs no data Rong Huang via Tech-talk
Re: archive appliance some PVs no data Rong Huang via Tech-talk
Re: archive appliance some PVs no data Shen, Guobao via Tech-talk
Prev: Re: archive appliance some PVs no data Shen, Guobao via Tech-talk
Next: RE: Video camera recommendation? Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: archive appliance some PVs no data Michael Davidsaver via Tech-talk
