1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Video camera recommendation?
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Donny Domagoj Cosic <[email protected]>
Date: Tue, 24 Sep 2024 06:30:32 +0000
Hello Mark
Did this setup help resolve issues where the acquisition suddenly stops and the solution was to check and increase the jumbo frames? As the camera is connected directly to a NIC, I assume you would have no issues even at high frame rates?
Thanks!
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Monday, September 23, 2024 4:04 PM
To: Donny Domagoj Cosic <[email protected]>
Subject: Re: Video camera recommendation?
Hi Donny,
  • These cameras take up quite a lot of bandwidth, what parameters do you find to be optimal when even three of these cameras simultaneously, do you use any compression? Do you collect and broadcast the image using AreaDetectors?
We use the following strategies to mitigate network bandwidth issues:
  • Connect to camera directly to a dedicated NIC on the computer which will most frequently be viewing those images, using a private IP.  That computer runs the IOC.  It can share the images on the network via PVA or CA.
  • Run the camera only at the frame rate needed for the application.
  • Run the CA or PVA plugin that shares the images on the network at the minimum rate required, for example 5 Hz.
  • Use the NDPluginCodec to do JPEG compression of the images before sharing on network with PVA.  This can reduce bandwidth 10X with no visible loss of quality.
  • For color cameras always do the Bayer to RGB conversion on the IOC, not on the camera.  This reduces bandwidth by a factor of 3.
We have several computers with 3 cameras each.  These use dedicated NICs and mainly local display, and that works fine.
Sent: Monday, September 23, 2024 4:08 AM
Cc: Jesse Hopkins <[email protected]>; EPICS Tech Talk <[email protected]>
Thank you,
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @:
[email protected] | www.irb.hr
Dana 2024-09-19 22:04, Mark Rivers via Tech-talk je napisao(la):
Hi Jesse,
I just bought 3 of these cameras for exactly the purpose you describe:
FLIR BlackFly S GigE, model BFS-PGE-23S6C-C.
  • Color
  • 2.3 MP (1920x1200)
  • 41 frames/s
  • $580
https://www.flir.com/products/blackfly-s-gige/?model=BFS-PGE-23S6C-C&vertical=machine+vision&segment=iis
These cameras have a resolution and aspect ratio that matches many computer monitors.
Let me know if you have any questions.
From: Tech-talk <[email protected]> On Behalf Of Jesse Hopkins via Tech-talk
Sent: Thursday, September 19, 2024 1:17 PM
To: EPICS Tech Talk <[email protected]>
Subject: Video camera recommendation?
Hi folks,
We're looking to migrate all of our old analog video cameras around the beamline to ones that are digital, preferably GigE. Does anyone have recommendations for relatively cheap, reliable, color digital video cameras that integrate well with AreaDetector? Ideally something that's ~1080p in resolution.
Apologies if this has been asked before, I did a quick search of the archives and didn't turn up anything recent.
All the best.
- Jesse
Jesse Hopkins, PhD
Deputy Director
BioCAT, Sector 18
Advanced Photon Source
Video camera recommendation? Jesse Hopkins via Tech-talk
RE: Video camera recommendation? Mark Rivers via Tech-talk
Re: Video camera recommendation? Donny Domagoj Cosic via Tech-talk
Re: Video camera recommendation? Mark Rivers via Tech-talk
Prev: RE: archive appliance some PVs no data Abdalla Ahmad via Tech-talk
Next: FLIR SpinView on alma 9? John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Video camera recommendation? Mark Rivers via Tech-talk
Next: Phoebus: Default display file path Kuldeep Joshi via Tech-talk
