1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Simple CAN bus over ethernet interface
From: Götz Pfeiffer via Tech-talk <[email protected]>
To: "Evans, Richard K. (GRC-H000)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 27 Sep 2024 10:25:43 +0200
Hello Richard,
we have been using EPICS and the CAN Bus at the Helmholtz-Zentrum Berlin
for the last 25 years.
We started with VME Bus IOCs and vxWorks, later RTEMS.
However, we recently added support for Linux.
The newest version of our CAN Bus device support, MultiCAN,
runs with Linux and the PCAN-PCI Express FD card from PEAK-System.
Maybe you will give it a try, the web page is here:
You can start with "Demo", this has a script that builds an IOC with CAN bus
support and uses virtual CAN interfaces, so you don't need a physical
CAN interface for this.
Greetings
  Goetz
On 9/24/24 18:47, Evans, Richard K. (GRC-H000) via Tech-talk wrote:
Hello,
We have a new project requirement to read status via CAN bus into EPICS. Anyone have any advice on what CAN bus I/O hardware for a PC to buy?
Thanks!
/Rich
- Richard Evans, NASA Neil A. Armstrong Test Facility
  Information Systems Management
  https://urldefense.us/v3/__http://www.linkedin.com/in/rkevans__;!!G_uCfscf7eWS!bz-iDxADUWBxrOLRRBo-R1ZpgZWWhU7_9T-Te4aRAp3HHHBI8xcwNFzcjSKXDYdsxz7oNvjw9wrvJ2gCnlzQ1nxzds1uAVjt$
  ©216.973.4398
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen
enthalten. Wenn Sie diese E-Mail irrtümlich erhalten haben, informieren Sie
bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte
Kopieren, die Veröffentlichung sowie die unbefugte Weitergabe dieser Mail ist
nicht gestattet. This email may contain confidential and/or proprietary
information. If you have received this e-mail in error, please inform the
sender immediately and destroy this e-mail. Unauthorized copying, publishing or
distribution of this e-mail is not permitted.
Attachment: OpenPGP_0x77FDCADCE0C70ECF.asc
Description: OpenPGP public key
Attachment: OpenPGP_signature.asc
Description: OpenPGP digital signature
Simple CAN bus over ethernet interface Evans, Richard K. (GRC-H000) via Tech-talk
Prev: Re: Writing XML directly to area detector's NDAttributesFile PV Wolfman, Mark via Tech-talk
Next: Re: Using alternative build systems (meson) for IOCs/modules NICOLE Rémi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Simple CAN bus over ethernet interface Dmitry Yu. Bolkhovityanov via Tech-talk
Next: p4p and numpy 2.0 Torsten Bögershausen via Tech-talk
