1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: how to build base with symbols for Arm?
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 27 Sep 2024 21:43:15 +0200
Hey Pete,
for other architectures it is defined in the configure/os/CONFIG_SITE.${ARCH}.${ARCH}
e.g.
florian@palumapc1:os$ grep OPT_ CONFIG_SITE.linux-arm.linux-arm
florian@palumapc1:os$ grep OPT_ CONFIG_SITE.linux-x86_64.linux-x86_64
OPT_CFLAGS_YES += -g
OPT_CXXFLAGS_YES += -g
florian@palumapc1:os$ grep OPT_ CONFIG_SITE.linux-aarch64.linux-aarch64
Not sure why this is not defined for linux-arm by default, but if you add those two lines to configure/os/CONFIG_SITE.linux-arm.linux-arm it should build with debug symbols.
HTH,
Florian
Am 27.09.2024 um 21:37 schrieb Siddons, David via Tech-talk:
Sorry for the trivial question, but how do I tell base to build natively on Arm with -g to have debug symbols? I can't see anything in the docs to tell me.
Pete.
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
how to build base with symbols for Arm? Siddons, David via Tech-talk
Prev: how to build base with symbols for Arm? Siddons, David via Tech-talk
Next: Question about Text Entry widget of phoebus for "Datetime" selector type neu lzf via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
