1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: RE: OPCUA SSL problem
From: Majer Karel via Tech-talk <[email protected]>
Date: Mon, 7 Oct 2024 09:03:57 +0000
Hi Ralph,
I built the device support with UASdk, but the IOC crashes on startup with Segmentation fault:
#!../../bin/linux-x86_64/opcua
< envPaths
epicsEnvSet("IOC","iocopcua")
epicsEnvSet("TOP","/usr/EPICS/IOCs/opcua")
epicsEnvSet("EPICS_BASE","/usr/EPICS/epics-base")
epicsEnvSet("OPCUA","/usr/EPICS/support/opcua")
cd "/usr/EPICS/IOCs/opcua"
dbLoadDatabase "dbd/opcua.dbd"
opcua_registerRecordDeviceDriver pdbbase
opcuaSession PLC opc.tcp://192.168.0.250:4840
|0x84275B80| 08:59:26.822Z OpcUa_P_Socket_InitializeNetwork: RLIMIT_NOFILE:1048576 larger than supported FD_SETSIZE:1024
opcuaOptions PLC debug=1
Session PLC: setting option debug to 1
opcuaSetupPKI /usr/PKI
OPC UA: Warning - a PKI directory is writable, which may compromise security. (/usr/PKI/trusted/certs)
OPC UA: Warning - a PKI directory is writable, which may compromise security. (/usr/PKI/trusted/crl)
OPC UA: Warning - a PKI directory is writable, which may compromise security. (/usr/PKI/issuers/certs)
OPC UA: Warning - a PKI directory is writable, which may compromise security. (/usr/PKI/issuers/crl)
opcuaClientCertificate /usr/openssl/cert.der /usr/openssl/key.pem
opcuaOptions PLC sec-policy=Basic256Sha256
Session PLC: setting option sec-policy to Basic256Sha256
opcuaSubscription RockwellPSI PLC 100
dbLoadRecords("db/FCT-RockwellPSI.db")
cd "/usr/EPICS/IOCs/opcua/iocBoot/iocopcua"
iocInit
Starting iocInit
## EPICS R7.0.8
## Rev. 2024-05-07T19:43+0000
## Rev. Date build date/time:
OPC UA Client Device Support 0.10.0-dev (-); using Unified Automation C++ Client SDK v1.8.4-632
OPC UA: Autoconnecting sessions
Session PLC: (disconnect) already disconnected (Disconnected)
Session PLC: (setupIdentity) setting Anonymous token
Session PLC: (setupSecurity) no security configured
Segmentation fault (core dumped)
I could download only evaluation version 1.8.4 of UASdk and noticed that the device support should work up to version 1.7. Is there anything I can try to get this running?
Kind regards,
Karel
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, October 4, 2024 12:58 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: OPCUA SSL problem
Hi Karel,
The low-level client, Open62541 in your case, indeed handles most of the dealing with OpenSSL for the Secure OPC UA connections.
Hmmm... more things you could try:
  • In your container, install the evaluation bundle of the UA SDK. (The evaluation bundle has full features, just limited to one hour of runtime.) Build the OPCUA Device Support against that.
    The two IOC binaries (linked against Open62541 and UASDK-Eval) are drop-in compatible and you can run either one of them against your server. The Wireshark captures should be directly comparable. (UAExpert also uses the UASDK as its low-level client.)
  • Do the same thing on an older Linux version (using OpenSSL1) with the Open62541 client against one of the "binary distribution" tars (that have a fully working version of the OPCUA  Support with UASDK using OpenSSL1) to see if behavior changes between the OpenSSL versions.
  • Use the UASDK demo server (part of the mentioned bundle), where you have full access to the server certificates. You can create and configure the server with self-signed or CA-signed certificates and check how the IOC needs to be set up to be able to connect.
The key thing to find out is if the issue is caused by how the Device Support handles the open62541 client or by how the open62541 client handles OpenSSL or by the server acting differently from other servers.
Thanks for your help and patience!
Cheers,
~Ralph
Re: OPCUA SSL problem Ralph Lange via Tech-talk
OPCUA SSL problem Majer Karel via Tech-talk
RE: OPCUA SSL problem Majer Karel via Tech-talk
Prev: Re: p4p and numpy 2.0 Torsten Bögershausen via Tech-talk
Next: Re: OPCUA SSL problem Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: OPCUA SSL problem Ralph Lange via Tech-talk
