Hi Ralph,
I have some fairly good news. I built the IOC with the binary distribution and it connects to the server. I cannot read data though, because the IOC ignores security
setup and the server is configured in a way that it requires encryption. But I hope that using the full UA SDK will work.
So it seems that the problem is some incompatibility of open62541 client and the server used. I have dumped also working communication of open62541 and B&R OPCUA
server and noticed differences in OpenSecureChannelResponse of the two servers. The problematic server does not send Nonce field in the response, but I don’t understand the OPCUA protocol well enough to be able to tell how much of a problem it its.
Best regards,
Karel
On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, October 7, 2024 12:02 PM
To: EPICS Tech Talk <[email protected]>
Subject: Re: OPCUA SSL problem
I built the device support with UASdk, but the IOC crashes on startup with Segmentation fault:
#!../../bin/linux-x86_64/opcua
OPC UA Client Device Support 0.10.0-dev (-); using Unified Automation C++ Client SDK v1.8.4-632
OPC UA: Autoconnecting sessions
Segmentation fault (core dumped)
That fits exactly the other reports I have received. "Compiles but crashes."
I could download only evaluation version 1.8.4 of UASdk and noticed that the device support should
work up to version 1.7. Is there anything I can try to get this running?
Try the UASDK-based binary distribution tar from GitHub that matches your version of Base (exact match required) and distribution.
- Re: OPCUA SSL problem Ralph Lange via Tech-talk
- OPCUA SSL problem Majer Karel via Tech-talk
- RE: OPCUA SSL problem Majer Karel via Tech-talk
Uniblitz VCM-D1 shutter driver Blomley, Edmund (IBPT) via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
