Dear Lin, Thank you very much for your replies (also in my other Phoebus question mail; here I am still investigating). Your debug help was very helpful, because I figured out that in case of the unhandled error, instead of the REACT_APP_BASE_URL it used localhost:3000 (wrong host and wrong port). When I use export
REACT_APP_BASE_URL=http://olog:8080/Olog and run "npm ci" and "npm start" in an interactive docker container, the error changes to: Search Error I attach a screenshot of the debugger. I'd be happy If you can spot an obvious error. From the commandline
inside the olog-web container I still get expected results when
using curl, e.g. # {"hitCount":3,"logs":[{"id":0,"owner":"user","source":"#First entry\nFirst entry\n","description":"#First entry\nFirst entry","title":"First entry","level":"Urgent","state":"Active","createdDate":1727788595982,"modifyDate":null,"events":null,"logbooks":[{"name":"controls","owner":null,"state":"Active"}],"tags":[],"properties":[{"name":"resource","owner":null,"state":"Active","attributes":[{"name":"file","value":"","state":"Active"},{"name":"name","value":"","state":"Active"}]}],"attachments":[]},{"id":1,"owner":"user","source":"# Second Entry\n## This is a subheader\nSecond entry from user","description":"Second Entry\nThis is a subheader\nSecond entry from user","title":"Second Entry","level":"Info","state":"Active","createdDate":1727792498185,"modifyDate":null,"events":null,"logbooks":[{"name":"controls","owner":null,"state":"Active"}],"tags":[],"properties":[],"attachments":[]},{"id":2,"owner":"user","source":"# New changes to settings.ini\nSeems to not have worked","description":"New changes to settings.ini\nSeems to not have worked","title":"New changes to settings.ini","level":"Problem","state":"Active","createdDate":1727863879466,"modifyDate":null,"events":null,"logbooks":[{"name":"controls","owner":null,"state":"Active"}],"tags":[],"properties":[],"attachments":[]}]}curl http://olog:8080/Olog/logs/search?start=2024-09-10&end=now&from=0&size=30&sort=down Best regards, Am 03.10.2024 um 12:53 schrieb Wang,
Lin:
Hello Simon, Since my network connection to Docker Hub and NPM are very slow, I cannot do enough test regarding why your docker deployment does not work. But typically, the "Search Error, Could not reach the logbook service" error is because the configuration of REACT_APP_BASE_URL (which points to the Olog service) in phoebus-olog-web-client is incorrect or does not take effect. I think there are several ways to configure REACT_APP_BASE_URL: 1. Set the OS environment variable REACT_APP_BASE_URL. 2. Create a .env file that includes the definition of REACT_APP_BASE_URL, which you already did. 3. Directly modify the following line in phoebus-olog-web-client/src/config/customization.js: APP_BASE_URL: process.env.REACT_APP_BASE_URL, // e.g. http://localhost:8080/Olog for example to APP_BASE_URL: 'http://olog-service-ip-address:8080/Olog', // e.g. http://localhost:8080/Olog One debug method can be used to check whether the REACT_APP_BASE_URL is configured successfully, that is, press the F12 key on the web browser to open debug mode and navigate to "Network" tab, then check which URL has actually been sent. Attached is a screenshot in my environment. Regards, Lin-----原始邮件----- 发件人: "Dr. Simon Friederich via Tech-talk" <tech-talk at aps.anl.gov> 发送时间:2024-10-03 03:59:21 (星期四) 收件人: tech-talk at aps.anl.gov 主题: [SPAM] Phoebus Olog and Web Client Dear Kunal, Dear George, Dear Phoebus-Olog-Team, Phoebus Olog: I am currently testing olog as your modern alternative for elog. Thanks to your example from the repository [1], I have now a running elasticsearch, mongo and olog service. I can access it via Phoebus with the settings.ini: ################################ # Package org.phoebus.olog.es.api ################################# org.phoebus.logbook/logbook_factory=olog-es org.phoebus.olog.es.api/olog_url=https://urldefense.us/v3/__http://testmesaolog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCHrJ8zzX$ org.phoebus.olog.es.api/username=user org.phoebus.olog.es.api/password=userPass But I have some further questions I was not able to figure out for myself: - If I run the olog-docker I am in a demo mode with a user admin and user? - How do I customize my olog? I have found a cuple of files in phoebus-olog/src/main/resources. You mention a special github repository where only application.properties is used for this [2]. - Can I change these properties any time? (e.g. I need more logbooks, different users or tags?) - How do I add/remove users and/or groups? I do not quite understand the correct syntax in application.properties. Could you provide an example? E.g. I want admin, operator, rfeng, cryoeng. If it's not mandatory, I don't want to use the LDAP service, unless it makes everything easier. - Where are the logbooks stored and how would you backup them? - I have these two docker-managed volumes esdata and mongodata in the docker-compose.yml file. Are these important to backup? - Can I use a mongo-GUI like mongodb compass to manage the logbook or is mongo only a backend? (Sorry for such questions, but I am not familiar with this yet) Web client: Then I need to access the logbooks via webbrowser. Hence, I've looked at your phoebus-olog-web-client [3]. Based on your Dockerfile I've set up a docker container in the same network "olognet" where elastic, monogo and olog reside (though the ports are published on localhost) with a docker-compose file: Dockerfile: # Node 18 FROM node:22-alpine # FROM node:18-alpine RUN apk update && apk add curl bash WORKDIR /app ENV PATH=/app/node_modules/.bin:$PATH COPY . ./ RUN npm ci --silent \ && npx update-browserslist-db@latest # \ # && npm run build \ # && npm install -g serve # start app CMD ["npm", "start"] # CMD ["serve", "-s", "build"] docker-compose.yml networks: olognet: external: true services: olog-web: container_name: "olog-web" build: . ports: - "3000:3000" # - "6006:6006" # storybook for testing environment: TZ: Europe/Berlin # REACT_APP_BASE_URL: https://urldefense.us/v3/__http://olog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCK794Uuc$ # specified in .env file stdin_open: true # docker run -i, debug tty: true # docker run -t, debug networks: - olognet # command: ["/bin/bash"] # debug I've also copied .env.example to .env and adopted to REACT_APP_BASE_URL=https://urldefense.us/v3/__http://olog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCK794Uuc$ . From within the olog-web-container I can ping the olog container and see the expected answer when running curl: 21e0630b20ba:/app# curl https://urldefense.us/v3/__http://olog:8080/Olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCK794Uuc$ { "name" : "Olog Service", "version" : "5.0.0-SNAPSHOT", "elastic" : { "status" : "Connected", "clusterName" : "elasticsearch", "clusterUuid" : "h-dKVMuFTJSlXb0gxeFn2w", "version" : "co.elastic.clients.elasticsearch._types.ElasticsearchVersionInfo@78b8c4e7", "elasticHost" : "elastic", "elasticPort" : "9200" }, "mongoDB" : "{type=STANDALONE, servers=[{address=mongo:27017, type=STANDALONE, roundTripTime=0.5 ms, state=CONNECTED}]", "serverConfig" : { "maxFileSize" : 50.0, "maxRequestSize" : 100.0 } Yet, if I access the web view on port 3000 it show the error message: Search Error Could not reach the logbook service So my question is do you see my mistake or can you tell me how to debug my issue? Thank you very much in advance Best regards Simon [1] https://urldefense.us/v3/__https://github.com/Olog/phoebus-olog__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCAMBxssS$ [2] https://urldefense.us/v3/__https://github.com/willrogers/olog-es-docker__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCAEkg_SM$ [3] https://urldefense.us/v3/__https://github.com/Olog/phoebus-olog-web-client__;!!G_uCfscf7eWS!dso4dmkrF-LWpZlpdNz3MRexqz8vRrLcyJnfweqt58VzNYt-zlwPQTyYVFpwEeDeXJQs8xSu-UMk4ZV4BLuBn_nBCDdGhnsq$ -- Dr. Simon Friederich Institute of Nuclear Physics Collaboration B | MESA Johannes Gutenberg-Universität Mainz Johann-Joachim-Becherweg 45 55128 Mainz, Germany phone: +49 (0)6131 39-23160 E-Mail: s.friederich at uni-mainz.de Attachment:
ANJ, 08 Oct 2024 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
