Hi Iain,
The EPICS build system does quite a lot of code generation, GNUmake handles that well. I think you’ll need to explain a bit more about what’s different about your process (what does it need to do?) for us
to be able to suggest some answers.
- Andrew
Complexity comes for free, Simplicity you have to work for.
I am looking to submit a pull request to incorporate a new quadEM IOC into the official package. The build process uses code-generation, and I don’t see an obvious way to invoke that at build time. Alternatively,
I could generate and commit the code, then send a pull request for that, if that would be better, but I would definitely also want to include the template files used as a basis for the generated code. What approach would be best for this submission?
Thank you,
Iain Marcuson.
This message has been scanned for malware by Forcepoint.
www.forcepoint.com
- Re: synApps quadEM build-time code generation Iain Marcuson via Tech-talk
- synApps quadEM build-time code generation Iain Marcuson via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
