Protocol looks fine, very similar to ours. Another thing to look for is trying updating the device’s firmware, we faced a similar issue years ago with our Gamma QPC model and the solution was to update all devices’ firmware. In more details,
the issue was a LOT of input mismatch exception. For example, the IOC requests a pressure reading and it gets a voltage reading in return, therefore an exception occurs resulting in an INVALID alarm severity.
Best Regards,
Abdalla.
Last time we had something similar adding this:
@replytimeout { disconnect; wait
1000; connect
1000;}
To the protocol solved everything. It was a suggestion from someone, I think Mark.
Cheers :)
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk
<[email protected]>
Sent: 14 October 2024 11:53:14
To: EPICS Tech Talk
Subject: Re: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time
(Without looking at your protocols...)
That out-of-sync behavior often happens when the device takes an unusually long time to reply once in a while. (E.g., a small controller that has to do something at higher priority for a while.)
The IOC times out and sends the next request, then the device sends the reply to the last request, which the IOC doesn't like. The IOC sends the next request, the device answers with the reply for the previous request, and so on...
Try increasing your timeouts, so that the IOC waits even in the cases where the device takes a break. Analyze your log timestamps. Are specific commands taking longer? Increase the timeout for those. I have also seen devices taking a nap
after specific commands complete successfully - in those cases, "wait;" instructions in the protocol can keep StreamDevice from sending the next command immediately.
- Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Dr. Simon Friederich via Tech-talk
- Re: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Ralph Lange via Tech-talk
- Re: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Marco Filho via Tech-talk
Re: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Dr. Simon Friederich via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
