Hi Jesse,
The plan outlined for setting up a CS motor using the Galil driver
sounds correct to me.
Following this through, I found a bug in the provided
galil_csmotor_kinematics.adl medm screen.
The text entry widget has been updated to type string now. The fix has
been pushed to github for versions 3-6-90 and 4-0-01.
The Galil driver example IOC provides motor record support for CS motors
I through P, and sscan support.
CS motors can also be used for on the fly scans in linear or PVT mode
(results are similar for linear/PVT modes).
Here are some tips for using Galil driver CS motors for point to point
moves:
Background:
On the galil_dmc_ctrl.adl screen there is a PV/setting "Deferred moves
mode" that has enumerated options "Sync start/stop" or "Sync start only".
A) "Sync start/stop" mode
To use a controller coordinate system (ie. S or T) then set "Deferred
moves mode" to "Sync start/stop". In this case linear coordinated
motion is used for the move.
The motor group will begin and complete motion synchronously. This mode
provides the highest level of coordination and synchronicity.
A) "Sync start only" mode
With "Sync start only" mode, a controller coordinate system is not
used. Instead the motor group have a synchronized start, and may also
complete at the same time, it is equation dependent.
With slit equations it's expected that the motors will also complete the
move in a synchronized way. Greater coordination can be achieved using
"Sync start/stop" than using the "Sync start only" mode, particularly
for motion complete synchronization.
Good luck with your project.)
Kind regards,
Mark Clift
This email has been checked for viruses by AVG antivirus software.
https://urldefense.us/v3/__http://www.avg.com__;!!G_uCfscf7eWS!c7S8XhURxsVwJ6GET0jOkuAj1lAlZjky6iU51rBn96g5zdU8lTwWWHKeTjbIDPudxrz8iC2ZlwR3N_0Tvng$
- Re: [Ext] RE: Help setting up coordinated motions for Galil controller Jesse Hopkins via Tech-talk
EPICS 2025 Spring meeting plan Han Lee via Tech-talk
Re: Asyn + Streamdevice: Gamma Vacuum Digtial QPC, missmatch after some time Dr. Simon Friederich via Tech-talk
<2024>
2025
RE: [Ext] RE: Help setting up coordinated motions for Galil controller Mark Rivers via Tech-talk
<2024>
2025
