1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Measurement Computing DT8824 DAQ Sampling Time Issue
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Mon, 21 Oct 2024 07:40:42 +0000
Hi
We are using the DT8824 DAQ with our own asyn-driver and the system is working fine with few seconds sampling rate. Recently there have been requirements to use faster sampling rates up to 0.2 seconds. Upon investigation, I could not go below 0.8 seconds, going below that will always give an empty scan record returned by the DAQ itself regardless of the ADC frequency and the number of samples requested. The aforementioned sampling rate is implemented as a sleep in the main thread, on each iteration we do this sequence of commands:
:AD:ABORT
:AD:ARM
:AD:INIT
Sleep
:AD:FETCH?
As I said this has been working fine for 1 second and maybe few more seconds sampling rates. Here is the driver we wrote https://github.com/SESAME-Synchrotron/xafs-dt8824-daq/ . Notice that the same scenario happens in a python script we wrote that uses the same interface as the driver itself. Any feedback is highly appreciated.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348
Fax: +96253511423
Email : [email protected]
Website: www.sesame.org.jo
Prev: Re: Help understanding DTYP Soft Timestamp Ralph Lange via Tech-talk
Next: Re: Help understanding DTYP Soft Timestamp Marco Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: adding ffmpegServer plugin to IOC Mark Rivers via Tech-talk
Next: Job Opening BESSY-II EPICS and Bluesky Smith, William via Tech-talk
