1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: genSubRecord.h not found
From: Andy Foster via Tech-talk <[email protected]>
To: LONG FENG <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 31 Oct 2024 08:00:55 +0000
Hi Feng,
You would need to build the genSub support module and reference this in your build, to use the genSub record.
However, these days, you should use the aSub record, which is a standard part of EPICS base. aSub = Array Subroutine Record.
The genSub = General Subroutine Record was the forerunner to the aSub, written many years ago, but probably still in use in many places.
Conversion between the two is not too difficult.
Cheers, Andy
On Thu, 31 Oct 2024, 03:16 LONG FENG via Tech-talk, <[email protected]> wrote:
Hi all,
During compilation I got an error:
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory '/home/training/examples/dataProcessingApp/src/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/ics/tools/base-7.0.6/include/compiler/gcc -I/ics/tools/base-7.0.6/include/os/Linux -I/ics/tools/base-7.0.6/include   -I/ics/tools/ether_ip/include   -I/ics/tools/seq-2.2.9/include  -I/ics/tools/autosave-R5-10-2/include/os/Linux -I/ics/tools/autosave-R5-10-2/include   -I/ics/tools/asyn4-38/include   -I/ics/tools/StreamDevice-master/include   -I/ics/tools/busy-1-6-1/include   -I/ics/tools/pvxs/include   -I/ics/tools/PyDevice-R1.1.1/include   -I/ics/tools/std/include         -c ../dose.c
../dose.c:6:10: fatal error: genSubRecord.h: No such file or directory
    6 | #include <genSubRecord.h>
compilation terminated.
make[1]: *** [/ics/tools/base-7.0.6/configure/RULES_BUILD:259: dose.o] Error 1
make[1]: Leaving directory '/home/training/examples/dataProcessingApp/src/O.linux-x86_64'
make: *** [/ics/tools/base-7.0.6/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
Do I need to install any additional modules to use genSubRecord?
Feng
Re: genSubRecord.h not found Andy Foster via Tech-talk
genSubRecord.h not found LONG FENG via Tech-talk
Prev: genSubRecord.h not found LONG FENG via Tech-talk
Next: Re: genSubRecord.h not found Andy Foster via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
