1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: genSubRecord.h not found
From: Andy Foster via Tech-talk <[email protected]>
To: LONG FENG <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 31 Oct 2024 11:43:57 +0000
Hi Feng,
I should have said, if you do want the code for the genSub support, then I can see it exists on github in a couple of places at least!
This is a good one to look at:
Cheers, Andy
On Thu, Oct 31, 2024 at 8:00 AM Andy Foster <[email protected]> wrote:
Hi Feng,
You would need to build the genSub support module and reference this in your build, to use the genSub record.
However, these days, you should use the aSub record, which is a standard part of EPICS base. aSub = Array Subroutine Record.
The genSub = General Subroutine Record was the forerunner to the aSub, written many years ago, but probably still in use in many places.
Conversion between the two is not too difficult.
Cheers, Andy
On Thu, 31 Oct 2024, 03:16 LONG FENG via Tech-talk, <[email protected]> wrote:
Hi all,
During compilation I got an error:
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory '/home/training/examples/dataProcessingApp/src/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/ics/tools/base-7.0.6/include/compiler/gcc -I/ics/tools/base-7.0.6/include/os/Linux -I/ics/tools/base-7.0.6/include   -I/ics/tools/ether_ip/include   -I/ics/tools/seq-2.2.9/include  -I/ics/tools/autosave-R5-10-2/include/os/Linux -I/ics/tools/autosave-R5-10-2/include   -I/ics/tools/asyn4-38/include   -I/ics/tools/StreamDevice-master/include   -I/ics/tools/busy-1-6-1/include   -I/ics/tools/pvxs/include   -I/ics/tools/PyDevice-R1.1.1/include   -I/ics/tools/std/include         -c ../dose.c
../dose.c:6:10: fatal error: genSubRecord.h: No such file or directory
    6 | #include <genSubRecord.h>
compilation terminated.
make[1]: *** [/ics/tools/base-7.0.6/configure/RULES_BUILD:259: dose.o] Error 1
make[1]: Leaving directory '/home/training/examples/dataProcessingApp/src/O.linux-x86_64'
make: *** [/ics/tools/base-7.0.6/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
Do I need to install any additional modules to use genSubRecord?
Feng
genSubRecord.h not found LONG FENG via Tech-talk
Re: genSubRecord.h not found Andy Foster via Tech-talk
Prev: Re: genSubRecord.h not found Andy Foster via Tech-talk
Next: RE: [External] Cs studio cannot load model form Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Procserv execute error 백호령 via Tech-talk
