1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: a compilation error in the aSub processing function.
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Sat, 2 Nov 2024 12:24:30 +0100
Hi Feng,
It seems you are building a library dataProcessingSupport (where your dose.c object is added), but you're not linking it to your IOC binary.
Try adding
dataProcessing_LIBS += dataProcessingSupport
Cheers,
~Ralph
a compilation error in the aSub processing function. LONG FENG via Tech-talk
Prev: Re: IOC Shell Persist history: ERROR Permission denied (13) writing '.iocsh_history' Ralph Lange via Tech-talk
Next: An error occurred while using aSub to process Modbus data LONG FENG via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: a compilation error in the aSub processing function. LONG FENG via Tech-talk
ANJ, 04 Nov 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
