Hi all,
I encountered the following errors while writing the processing function for the aSub record. make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 installmake[1]: Entering directory '/home/training/examples/dataProcessingApp/src/O.linux-x86_64' /usr/bin/g++ -o dataProcessing -L/home/training/examples/lib/linux-x86_64 -L/ics/tools/StreamDevice-master/lib/linux-x86_64 -L/ics/tools/asyn4-38/lib/linux-x86_64 -L/ics/tools/base-7.0.6/lib/linux-x86_64 -Wl,-rpath,/home/training/examples/lib/linux-x86_64 -Wl,-rpath,/ics/tools/StreamDevice-master/lib/linux-x86_64 -Wl,-rpath,/ics/tools/asyn4-38/lib/linux-x86_64 -Wl,-rpath,/ics/tools/base-7.0.6/lib/linux-x86_64 -rdynamic -m64 dataProcessing_registerRecordDeviceDriver.o dataProcessingMain.o -ldbRecStd -ldbCore -lca -lCom -lasyn -lstream /usr/bin/ld: dataProcessing_registerRecordDeviceDriver.o: in function `dataProcessing_registerRecordDeviceDriver': /home/training/examples/dataProcessingApp/src/O.linux-x86_64/dataProcessing_registerRecordDeviceDriver.cpp:412: undefined reference to `pvar_func_register_func_dose' collect2: error: ld returned 1 exit status make[1]: *** [/ics/tools/base-7.0.6/configure/RULES_BUILD:231: dataProcessing] Error 1 make[1]: Leaving directory '/home/training/examples/dataProcessingApp/src/O.linux-x86_64' make: *** [/ics/tools/base-7.0.6/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 My function(dose.c) content is as follows : #include <stdint.h> #include <epicsExport.h> #include <aSubRecord.h> #include <registryFunction.h> int dose(aSubRecord *psub) { char *inData; double *pout1, doseRate; unsigned char readData[4] = {0}; double *p1, *p2; inData = (char *)psub->a; pout1 = (double *)psub->vala; p1 = (double *)psub->valb; p2 = (double *)psub->valc; readData[0] = inData[4]; readData[1] = inData[3]; readData[2] = inData[6]; readData[3] = inData[5]; //Convert to floating point number doseRate = *((float*)readData); // result *pout1 = doseRate; return 0; } epicsRegisterFunction(dose); dose.dbd: function(dose) Makefile: TOP=../.. include $(TOP)/configure/CONFIG #---------------------------------------- # ADD MACRO DEFINITIONS AFTER THIS LINE #============================= #============================= # Build the IOC application PROD_IOC = dataProcessing # dataProcessing.dbd will be created and installed DBD += dataProcessing.dbd # dataProcessing.dbd will be made up from these files: dataProcessing_DBD += base.dbd dataProcessing_DBD += dose.dbd # Build an IOC support library LIBRARY_IOC += dataProcessingSupport # Compile and add code to the support library dataProcessingSupport_SRCS += dose.c # dataProcessing_registerRecordDeviceDriver.cpp derives from dataProcessing.dbd dataProcessing_SRCS += dataProcessing_registerRecordDeviceDriver.cpp # Build the main IOC entry point on workstation OSs. dataProcessing_SRCS_DEFAULT += dataProcessingMain.cpp dataProcessing_SRCS_vxWorks += -nil- # Add support from base/src/vxWorks if needed #dataProcessing_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary # Finally link to the EPICS Base libraries dataProcessing_LIBS += $(EPICS_BASE_IOC_LIBS) ##### ADDED FOR STREAM DEVICE ############ dataProcessing_DBD += stream.dbd dataProcessing_DBD += asyn.dbd dataProcessing_DBD += drvAsynSerialPort.dbd dataProcessing_LIBS += asyn dataProcessing_LIBS += stream #=========================== include $(TOP)/configure/RULES #---------------------------------------- # ADD RULES AFTER THIS LINE Where is the issue, and how should I resolve the error? Feng
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
