1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: An error occurred while using aSub to process Modbus data
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: LONG FENG <feng98716 at gmail.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 4 Nov 2024 11:33:32 +0000
Hi Feng,
I can see a few things differently from how I use aSub, I hope they can be of help. I will note them inline.
Cheers,
Érico
On 04/11/2024 05:55, LONG FENG via Tech-talk wrote:
Hi all,
I want to process Modbus format data, but it's not going very smoothly.
My record file content is as follows:
record(waveform, "Sensor:waveform")
    field(DESC, "read data")
    field(DTYP, "stream")
    field(NELM, "40")
    field(FTVL, "UCHAR")
    field(INP, "@RS485Test.proto getData SI")
    field(SCAN, "5 second")
    field(FLNK, "ProcessSensorData")
I'm assuming you have made sure that Sensor:waveform is working correctly, and that ProcessSensorData is being processed as well.
record(aSub, "ProcessSensorData")
    field(INAM, "init_dose")
    field(SNAM, "dose")
    field(INPA, "Sensor:waveform NPP NMS")
Setting FTA and NOA here might also be useful.
    field(FTVE, "DOUBLE")
This field should be FTVA, no?
    field(OUTA, "Sensor:ai NPP NMS")
I normally use PP for output records.
    field(NOVA, "1")
record(ai, "Sensor:ai")
    field(DESC, "Dose Measurement")
    field(INP, "ProcessSensorData.VALA NPP NMS")
You don't need an INP field in this record, the ProcessSensorData record will write into it already.
    field(PREC, "3")
    field(EGU, "µSv/h")
    field(SCAN, "Passive")
dose.c:
#include <epicsExport.h>
#include <aSubRecord.h>
#include <registryFunction.h>
int init_dose(struct aSubRecord *psub) {
    double *p1 = (double *)psub->vala;
    *p1 = 0;
    return 0;
int dose(struct aSubRecord *psub) {
    char *inData;
    double *pout1, doseRate;
    unsigned char readData[4] = {0};
    inData = (char *)psub->a;
    pout1 = (double *)psub->vala;
For example, the returned data is: 01 04 0c 14 7b 3e 2e 00 03 00 00 00 00 00 00 ad c9. '14 7b' represents the low byte, and '3e 2e' represents the high byte.
    readData[0] = inData[4];
    readData[1] = inData[3];
    readData[2] = inData[6];
    readData[3] = inData[5];
    doseRate = *((float*)readData);
C detail and probably not relevant for your issue, I don't think you can guarantee readData is correctly aligned for a float. A more portable implementation could use memcpy to copy readData into an intermediary float variable.
    *pout1 = doseRate;
You're not setting "psub->neva" to 1 here, to indicate that you wrote into one value of this array.
    return 0;
epicsRegisterFunction(init_dose);
epicsRegisterFunction(dose);
 I used caget to observe Sensor:ai, and the result is always:
Sensor:ai                      2.20405e-38
I think I made a mistake in my processing function, so I wrote a simple test program as follows:
    *p1 = 0;
    return 0;
    char *inData;
    doseRate = inData[3]*0.1;
    *pout1 = doseRate;
    return 0;
However, the result is always:
Sensor:ai                      0
What should I modify? Please help me.
Feng
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
An error occurred while using aSub to process Modbus data LONG FENG via Tech-talk
Prev: An error occurred while using aSub to process Modbus data LONG FENG via Tech-talk
Next: Re: Smaract MCS2 position polling issue Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Next: RE: An error occurred while using aSub to process Modbus data Mark Rivers via Tech-talk
ANJ, 05 Nov 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
