1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Keithley DMM7510 / DMM6500
From: Lucas Russo via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>
Cc: [email protected], "[email protected] \([email protected]\)" <[email protected]>
Date: Mon, 11 Nov 2024 10:43:38 -0800
Hi Yong,
1. I generated the .pdf files for you. You likely need
some extra fonts like "cm-super". I uploaded them here:
2. That seems like something is wrong with the .dbd files. Can you
share with me the compilation log?
3. For that one, I'll point you to my colleagues in LNLS/Sirius, in Cc,
as they are actively using this device and should be able to provide
more technical details.
Hope this helps,
Lucas
On Fri, Nov 8, 2024 at 2:46 PM Lucas Russo <[email protected]> wrote:
Hi Yong,
So, to answer a few of your questions:
1. See attached. I generated the .pdf files for you. You likely need
Hope this helps,
Lucas
On Wed, Oct 30, 2024 at 6:55 AM Hu, Yong via Tech-talk <[email protected]> wrote:
I have built dmm7510-epics-ioc and I am testing one DMM7510. From the CSS OPIs, I know my IOC is communicating with the DMM after I manually configured the Command Set as TSP instead of the default SCPI.
Has anyone successfully got a waveform data (100K samples) using an external trigger at 1Hz? If so, what is the trick (which PVs should I pay special attention to)?
I have contacted a few persons privately, including the original developers. But no response yet.
Yong
NSLS-2 Accelerator Controls Group
From: Tech-talk <[email protected]> on behalf of Henrique Silva via Tech-talk <[email protected]>
Date: Wednesday, March 29, 2023 at 7:55 AM
To: Leicester, Pete (DLSLtd, RAL, LSCI) <[email protected]>
Cc: Limem, Ahmed (DLSLtd, RAL, LSCI) <[email protected]>, [email protected] <[email protected]>
Subject: Re: Keithley DMM6500
I know that there is a streamdevice-based IOC developed by Sirius for the DMM7510 https://github.com/lnls-dig/dmm7510-epics-ioc.
A quick look in the manuals shows me that the 6500 and 7510 are similar enough that you would need small adaptations to get this one working for your model.
Note that this IOC uses the TSP interface and not SCPI, but both models support it.
Cheers,
Henrique Silva
From: Tech-talk <[email protected]> on behalf of Leicester, Pete (DLSLtd, RAL, LSCI) via Tech-talk <[email protected]>
Sent: 29 March 2023 10:52:44
To: '[email protected]'
Cc: Limem, Ahmed (DLSLtd,RAL,LSCI)
Subject: Keithley DMM6500
Does anyone have an EPICS driver for the Keithley DMM6500 Digital Multimeter (Keithley DMM6500 6.5 Digit Multimeter with Graphical Touchscreen | Tektronix)?
My brief search of EPICS Support Modules (anl.gov) didn’t reveal anything, is this still the best place to look?
Pete
Pete Leicester
Diamond Light source
Re: Keithley DMM7510 / DMM6500 Hu, Yong via Tech-talk
Prev: Re: Multiple asyn ports inside asynPortDriver class Jure Varlec via Tech-talk
Next: Very stange compile error on Windows Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Keithley DMM7510 / DMM6500 Hu, Yong via Tech-talk
Next: Re: Keithley DMM7510 / DMM6500 Hu, Yong via Tech-talk
