1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: Keithley DMM7510 / DMM6500
To: Lucas Russo <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected] \([email protected]\)" <[email protected]>
Date: Fri, 15 Nov 2024 16:59:31 +0000
Hi Lucas,
Thanks for the PDF documentation files which are really helpful. After reading ICT_App_User_Guide.pdf, I can make the DMM work with an external trigger.
I revisited the directory dmm7510/documentation. Indeed there is a file missfont.log which has a long list. I installed the cm-super related package, but there are still quite a few other errors. If your time is permitted, I would like you to upload those PDF files to GitHub just in case other people have the same issue of generating them.
The software package, including the StreamDevice-based driver and the CSS OPIs, is comprehensive. There are a few things I would like to discuss with you and your colleagues in private.
Cheers,
Yong
Date: Monday, November 11, 2024 at 1:43 PM
To: Hu, Yong <[email protected]>
Cc: [email protected] ([email protected]) <[email protected]>, Andrei Guinancio de Carvalho Pereira <[email protected]>, [email protected] <[email protected]>
Hi Yong,
1. I generated the .pdf files for you. You likely need
some extra fonts like "cm-super". I uploaded them here:
2. That seems like something is wrong with the .dbd files. Can you
share with me the compilation log?
3. For that one, I'll point you to my colleagues in LNLS/Sirius, in Cc,
as they are actively using this device and should be able to provide
more technical details.
Hope this helps,
Lucas
On Fri, Nov 8, 2024 at 2:46PM Lucas Russo <[email protected]> wrote:
Hi Yong,
So, to answer a few of your questions:
1. See attached. I generated the .pdf files for you. You likely need
Hope this helps,
Lucas
On Wed, Oct 30, 2024 at 6:55AM Hu, Yong via Tech-talk <[email protected]> wrote:
I have built dmm7510-epics-ioc and I am testing one DMM7510. From the CSS OPIs, I know my IOC is communicating with the DMM after I manually configured the Command Set as TSP instead of the default SCPI.
Has anyone successfully got a waveform data (100K samples) using an external trigger at 1Hz? If so, what is the trick (which PVs should I pay special attention to)?
I have contacted a few persons privately, including the original developers. But no response yet.
Yong
NSLS-2 Accelerator Controls Group
From: Tech-talk <[email protected]> on behalf of Henrique Silva via Tech-talk <[email protected]>
Date: Wednesday, March 29, 2023 at 7:55 AM
To: Leicester, Pete (DLSLtd, RAL, LSCI) <[email protected]>
Cc: Limem, Ahmed (DLSLtd, RAL, LSCI) <[email protected]>, [email protected] <[email protected]>
Subject: Re: Keithley DMM6500
I know that there is a streamdevice-based IOC developed by Sirius for the DMM7510 https://github.com/lnls-dig/dmm7510-epics-ioc.
A quick look in the manuals shows me that the 6500 and 7510 are similar enough that you would need small adaptations to get this one working for your model.
Note that this IOC uses the TSP interface and not SCPI, but both models support it.
Cheers,
Henrique Silva
From: Tech-talk <[email protected]> on behalf of Leicester, Pete (DLSLtd, RAL, LSCI) via Tech-talk <[email protected]>
Sent: 29 March 2023 10:52:44
To: '[email protected]'
Cc: Limem, Ahmed (DLSLtd,RAL,LSCI)
Subject: Keithley DMM6500
Does anyone have an EPICS driver for the Keithley DMM6500 Digital Multimeter (Keithley DMM6500 6.5 Digit Multimeter with Graphical Touchscreen | Tektronix)?
My brief search of EPICS Support Modules (anl.gov) didn’t reveal anything, is this still the best place to look?
Pete
Pete Leicester
Diamond Light source
Keithley DMM7510 / DMM6500 Hu, Yong via Tech-talk
Re: Keithley DMM7510 / DMM6500 Lucas Russo via Tech-talk
Prev: RE: [Ext] RE: Help with motorNewport config Mark Rivers via Tech-talk
Next: ADVimba IOC boot recGblRecordError NDPluginDriver errors Rong Huang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: Re: Keithley DMM7510 / DMM6500 Lucas Russo via Tech-talk
Next: Cs studio cannot load model form Saunders, Wyatt via Tech-talk
