subject : I am having issues with CS studio after switching release versions.
Hi, this morning I wanted to run cs studio I was originally using the latest snapshot. however, my Java Runtime was not up to date and could not recognize class file version 61.0 and could only recognize up to 55.0. I decided to switch to an official release
of cs-studio so i would not have to worry about updating things.
this is the current configuration I have
installed location: /home/saunders/cs_studio/Phoebus-4.7.3-linux/product-4.7.3
current user directory: /home/saunders/cs_studio/Phoebus-4.7.3-linux/product-4.7.3
java home: /usr/lib/jvm/java-11-openjdk-11.0.20.1.1-2.el9.x86_64
cs studio version: 4.7.3
java version Oracle Corporation 11.0.20.1+1-LTS
java FX vesion 19+11
cs studio will now open but when i try to run one of the .bob files to test one of my displays i get the following error pop up with the following text
cannot load model from
/home/saunders/cs_studio/vacumeguagetest.bob
could not initialize class java.awt.Color
java.lang.NoClassDefFoundError: could not initialize class java.awt.Color
Cause:
[1] could not initialize class java.awt.Color
under the see details it says this
java.util.concurrent.ExecutionException: java.lang.NoClassDefFoundError: Could not initialize class java.awt.Color
at java.base/java.util.concurrent.FutureTask.report(FutureTask.java:122)
at java.base/java.util.concurrent.FutureTask.get(FutureTask.java:191)
at org.csstudio.display.builder.runtime.app.DisplayRuntimeInstance.lambda$loadDisplayFile$4(DisplayRuntimeInstance.java:304)
at org.phoebus.framework.jobs.Job.execute(Job.java:50)
at org.phoebus.framework.jobs.JobManager.execute(JobManager.java:54)
at org.phoebus.framework.jobs.JobManager.lambda$schedule$0(JobManager.java:45)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class java.awt.Color
at org.csstudio.display.builder.representation.javafx.JFXRepresentation.updateBackground(JFXRepresentation.java:855)
at org.csstudio.display.builder.representation.javafx.JFXRepresentation.execute(JFXRepresentation.java:672)
at org.csstudio.display.builder.representation.javafx.JFXRepresentation.lambda$new$1(JFXRepresentation.java:153)
at org.csstudio.display.builder.representation.javafx.JFXRepresentation.representModel(JFXRepresentation.java:642)
at org.csstudio.display.builder.runtime.app.DockItemRepresentation.representModel(DockItemRepresentation.java:142)
at org.csstudio.display.builder.runtime.app.DisplayRuntimeInstance.representModel(DisplayRuntimeInstance.java:400)
at org.csstudio.display.builder.runtime.app.DisplayRuntimeInstance.lambda$loadDisplayFile$2(DisplayRuntimeInstance.java:303)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:457)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:456)
at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
at com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
at com.sun.glass.ui.gtk.GtkApplication.lambda$runLoop$11(GtkApplication.java:316)
... 1 more
this is the case for any of the displays I try and run including the displays that come with the program including the home display. If anyone has any insight into what is going on here please let me know
thanks,
Wyatt
