1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Very stange compile error on Windows
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: "'Johnson, Andrew N.'" <[email protected]>, "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Nov 2024 00:00:24 +0000
Hi Mark,
This does look like the same error reported at Compile error with isnan/isinf and Visual Studio 2022 17.11.1 · Issue #541 · epics-base/epics-base – I saw this after I had updated the compiler, so I can only suggest as Andrew has that somehow your compiler has received an automatic update of some sort.
Freddie
From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
Sent: 11 November 2024 23:36
To: Rivers, Mark L. <[email protected]>; [email protected]
Subject: Re: Very stange compile error on Windows
Hi Mark,
Can you try replacing the modules/libcom/src/osi/os/WIN32/epicsMath.h file in your version of Base 7.0.7 with the one from the 7.0 branch of git? Freddie added some guards in August which might be relevant to this error, although I’m not sure of that. I’m speculating that your MSVC header files might have somehow received an automatic update which broke this compilation.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 11/11/24, 5:12 PM, "Tech-talk" <[email protected]> wrote:
Folks,
I just tried to build ADCore on Windows, which has worked fine in the past.  Today I got an error compiling ADApp/pluginSrc/NDPluginCircularBuff.cpp.
I managed to reduce the problem to a 2-line test program that fails to compile.  This is test.cpp.
#include <epicsMath.h>
#include <epicsTime.h>
This is the error output when test.cpp is compiled:
cl -EHsc -GR           -DBUILDING_NDPlugin_API     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE    -Ox -Oy-   -W3 -w44355 -w44344 -w44251 -D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING     -DHAVE_JPEG -DHAVE_BLOSC -DHAVE_BITSHUFFLE -DLIBXML_STATIC -DLIBTIFF_STATIC -DH5_BUILT_AS_STATIC_LIB    -MT  -TP   -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include      -IJ:/epics/support/asyn-4-44-2/include     -IJ:/epics/support/areaDetector-3-13/ADSupport/include/os/WIN32 -IJ:/epics/support/areaDetector-3-13/ADSupport/include   -IJ:/epics/support/areaDetector-3-13/ADCore/include -IH:/epics/base-7.0.7/include/compiler/msvc -IH:/epics/base-7.0.7/include/os/WIN32 -IH:/epics/base-7.0.7/include        -c ../test.cpp
test.cpp
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): error C2588: '::!_finite': illegal global finalizer
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): error C2143: syntax error: missing ')' before '!'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): error C2143: syntax error: missing ';' before '!'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): error C2270: '_finite': modifiers not allowed on nonmember functions
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): error C2588: '::!_isnan': illegal global finalizer
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): error C2059: syntax error: ')'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): error C2556: 'bool _isnan(signed char) noexcept': overloaded function differs only by return type from 'int _isnan(signed char) noexcept'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(831): note: see declaration of '_isnan'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): error C2371: '_isnan': redefinition; different basic types
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): error C2556: 'bool _isnan(unsigned char) noexcept': overloaded function differs only by return type from 'int _isnan(unsigned char) noexcept'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): error C2556: 'bool _isnan(short) noexcept': overloaded function differs only by return type from 'int _isnan(short) noexcept'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): error C2556: 'bool _isnan(unsigned short) noexcept': overloaded function differs only by return type from 'int _isnan(unsigned short) noexcept'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): error C2556: 'bool _isnan(int) noexcept': overloaded function differs only by return type from 'int _isnan(int) noexcept'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): error C2556: 'bool _isnan(unsigned int) noexcept': overloaded function differs only by return type from 'int _isnan(unsigned int) noexcept'
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.41.34120\include\cmath(832): fatal error C1003: error count exceeds 100; stopping compilation
make[1]: *** [H:/epics/base-7.0.7/configure/RULES_BUILD:267: test.obj] Error 2
make[1]: Leaving directory 'J:/epics/support/areaDetector-3-13/ADCore/ADApp/pluginSrc/O.windows-x64-static'
make: *** [H:/epics/base-7.0.7/configure/RULES_ARCHS:58: install.windows-x64-static] Error 2
If I reverse the order of the 2 includes in test.cpp, i.e. include epicsTime.h before epicsMath.h then it builds fine.
test.cpp
(no error)
I was able to fix the problem with compiling NDPluginCircularBuff.cpp by including epicsTime.h before epicsMath.h.
There are 2 things that I don’t understand:
·         Why is this failing to compile.
·         Why did it previously work?  I have not knowingly updated Visual Studio or EPICS base (7.0.7), and NDPluginCircularBuffer.cpp was last changed in 2020.
Very stange compile error on Windows Mark Rivers via Tech-talk
Re: Very stange compile error on Windows Johnson, Andrew N. via Tech-talk
Prev: Re: Very stange compile error on Windows Johnson, Andrew N. via Tech-talk
Next: Phoebus: text color based on alarm severity Paul Sichta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: Very stange compile error on Windows Mark Rivers via Tech-talk
