1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Email configuration issue
To: [email protected]
Date: Tue, 26 Nov 2024 14:11:48 +0800
Hi all,
My settings in the phoebus settings.ini file are configured like this:
#org.phoebus.email/mailhost=smtp.ornl.gov
#org.phoebus.email/mailhost=DISABLE
#org.phoebus.applications.alarm/automated_email_sender=Alarm Notifier <[email protected]>
org.phoebus.email/mailhost=smtp.yeah.net
org.phoebus.applications.alarm/automated_email_sender=[email protected]
But it gives this error: Couldn't connect to host, port: smtp.bnl.gov, 25:
2024-11-26 10:12:18 INFO [org.phoebus.applications.alarm] /Accelerator/Photocathode/analog: Send email to [feng98716gmail.com]
2024-11-26 10:12:18 WARNING [org.phoebus.applications.alarm] Failed to email to feng98716gmail.com
com.sun.mail.util.MailConnectException: Couldn't connect to host, port: smtp.bnl.gov, 25; timeout -1;
  nested exception is:
        java.net.UnknownHostException: smtp.bnl.gov
        at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:2209)
        at com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:740)
        at javax.mail.Service.connect(Service.java:366)
        at javax.mail.Service.connect(Service.java:246)
        at javax.mail.Service.connect(Service.java:195)
        at javax.mail.Transport.send0(Transport.java:254)
        at javax.mail.Transport.send(Transport.java:124)
        at org.phoebus.email.EmailService.send(EmailService.java:78)
        at org.phoebus.email.EmailService.send(EmailService.java:66)
        at org.phoebus.applications.alarm.server.actions.EmailActionExecutor.sendEmail(EmailActionExecutor.java:49)
        at org.phoebus.applications.alarm.server.actions.AutomatedActionExecutor.lambda$accept$0(AutomatedActionExecutor.java:53)
        at org.phoebus.framework.jobs.Job.execute(Job.java:50)
        at org.phoebus.framework.jobs.JobManager.execute(JobManager.java:54)
        at org.phoebus.framework.jobs.JobManager.lambda$schedule$0(JobManager.java:45)
        at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
        at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
        at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
        at java.base/java.lang.Thread.run(Thread.java:842)
Caused by: java.net.UnknownHostException: smtp.bnl.gov
        at java.base/sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:572)
        at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:327)
        at java.base/java.net.Socket.connect(Socket.java:633)
        at java.base/java.net.Socket.connect(Socket.java:583)
        at com.sun.mail.util.SocketFetcher.createSocket(SocketFetcher.java:353)
        at com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:239)
        at com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:2175)
        ... 17 more
Aren’t the email settings supposed to be in the settings.ini file?
Feng
Prev: RE: EPICS support for SAES NEG POWER pump controller Mark Rivers via Tech-talk
Next: RE: EPICS support for SAES NEG POWER pump controller Dr. Simon Friederich via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: EPICS support for SAES NEG POWER pump controller Dr. Simon Friederich via Tech-talk
Next: Windows path syntax problem Mark Rivers via Tech-talk
