1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: EPICS support for SAES NEG POWER pump controller
To: "Hudson, Lee (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 Nov 2024 16:11:46 +0000
Hi Lee,
You probably know this, but you should not need to write any C/C++ code if the device uses Modbus RTU.  You just need to create .substitutions files and load drvModbusAsyn drivers in your startup script.
The SyringePump module has some good examples for the high-pressure syringe pumps from Teledyne ISCO and Vindum.  This is the directory with the .substitutions files:
https://github.com/epics-modules/SyringePump/tree/main/SPApp/Db
This is the startup script for the ISCO pumps:
https://github.com/epics-modules/SyringePump/blob/main/iocBoot/iocISCO/st.cmd
This is the startup script for the Vindum pumps:
https://github.com/epics-modules/SyringePump/blob/main/iocBoot/iocVindum/st.cmd
From: Tech-talk <[email protected]> On Behalf Of Hudson, Lee (DLSLtd,RAL,LSCI) via Tech-talk
Sent: Monday, November 25, 2024 9:04 AM
To: [email protected]
Subject: EPICS support for SAES NEG POWER pump controller
I was wondering if anyone has written EPICS support for this device? It looks like it communicates using Modbus RTU. I wanted to check before we look into writing support.
Thanks
Lee
Lee Hudson, Senior Software Engineer (Ext 8511)
Diamond Light Source LTD,
Diamond House,
Harwell Science & Innovation Campus,
Didcot,
Oxfordshire,
OX11 0DE.
TEL:  01235 778511
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
EPICS support for SAES NEG POWER pump controller Hudson, Lee (DLSLtd,RAL,LSCI) via Tech-talk
Prev: EPICS support for SAES NEG POWER pump controller Hudson, Lee (DLSLtd,RAL,LSCI) via Tech-talk
Next: Email configuration issue LONG FENG via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: EPICS support for SAES NEG POWER pump controller Dr. Simon Friederich via Tech-talk
