1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: ADVimba R1-5 released
Date: Sun, 1 Dec 2024 20:22:45 +0000
Folks,
ADVimba R1-5 is available.  These are the release notes:
  • Added support for reconnecting the camera to the driver after network interruption or power-cycling the camera.
    • Added code to receive callbacks when the Vimba SDK detects connects or disconnects.
    • Added code to process manual connect and disconnect events, for example using asynRecord.
    • Call pasynManager->exceptionConnect or exceptionDisconnect when the camera connection state changes. This causes the current connection state to be displayed in OPI screens and prevents device support calls to the driver when the camera is disconnected.
    • Changed VimbaFeature::isAvailble to reconnect to the feature after camera power cycle.
    • Added disconnectCamera() method.
  • Fix so the ADCore preAllocateBuffers method works.
  • Added exampleSrc directory for test programs.
    • testOpenClose.cpp tests connection management.
  • Fixed missing ADGenICamSupport.dbd in IOC Makefile.
Home: https://github.com/areaDetector/ADVimba
Documentation: https://areadetector.github.io/areaDetector/ADVimba/ADVimba.html
Prev: Modbus R3-4 released Mark Rivers via Tech-talk
Next: asyn R4-45 released Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
