1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: motorSymetrie issue
From: Pedro Gigoux via Tech-talk <[email protected]>
Date: Tue, 3 Dec 2024 11:49:19 -0300
Thank you, I'll try that.
Pedro.
On Tue, 3 Dec 2024 at 11:39, Mark Rivers <[email protected]> wrote:
Hi Pedro,
It is OK for DOL fields to be constants, they don't need to be links.  However, if they are constants then I think they need to be numeric, since they are converted to doubles in the DOn field (DO7 in this case).  The intention here is to write the choice CURRENT POSITION to the following mbbo record.  Since that has the enum value 0, I think the solution is to replace CURRENT POSITION with 0 in the DOL7 field, which will make the selection with a numeric value, rather than the string equivalent.
From: Tech-talk <[email protected]> on behalf of Pedro Gigoux via Tech-talk <[email protected]>
Sent: Tuesday, December 3, 2024 7:56 AM
To: [email protected] <[email protected]>
Subject: motorSymetrie issue
I encountered an issue in the motorSymetrie support module. The record SYM:HEX01:Drv:ValidateMove:CopyAndExecute has an invalid severity (NAMSG: field DOL7) because DOL7 is set to "CURRENT POSITION" in instead of a valid record name. This makes the field to be set to "DOL7: CA_LINK CURRENT NPP NMS" at boot time. The problem is located in the following section of SymetriePmac.template:
record(seq, "$(P)$(R)Drv:ValidateMove:CopyAndExecute") {
  field(PINI, "NO")
  field(DOL1, "$(P)$(R)MOVE_PTP:Tx")
  field(LNK1, "$(P)$(R)VALID_PTP:Tx PP")
  field(DLY1, "0.0")
  field(DOL2, "$(P)$(R)MOVE_PTP:Ty")
  field(LNK2, "$(P)$(R)VALID_PTP:Ty PP")
  field(DLY2, "0.0")
  field(DOL3, "$(P)$(R)MOVE_PTP:Tz")
  field(LNK3, "$(P)$(R)VALID_PTP:Tz PP")
  field(DLY3, "0.0")
  field(DOL4, "$(P)$(R)MOVE_PTP:Rx")
  field(LNK4, "$(P)$(R)VALID_PTP:Rx PP")
  field(DLY4, "0.0")
  field(DOL5, "$(P)$(R)MOVE_PTP:Ry")
  field(LNK5, "$(P)$(R)VALID_PTP:Ry PP")
  field(DLY5, "0.0")
  field(DOL6, "$(P)$(R)MOVE_PTP:Rz")
  field(LNK6, "$(P)$(R)VALID_PTP:Rz PP")
  field(DLY6, "0.0")
  field(DOL7, "CURRENT POSITION")
  field(LNK7, "$(P)$(R)VALID_PTP:ValidationMode PP")
  field(DLY7, "0.0")
  field(DOL8, "$(P)$(R)MOVE_PTP:MoveType")
  field(LNK8, "$(P)$(R)VALID_PTP:MoveType PP")
  field(DLY8, "0.0")
  field(DOL9, "1")
  field(LNK9, "$(P)$(R)VALID_PTP.PROC PP")
  field(DLY9, "0.0")
It should be easy to fix, but I'm not sure what record/field DOL7 should be set to. Any suggestions?
Thank you,
Pedro.
motorSymetrie issue Pedro Gigoux via Tech-talk
Re: motorSymetrie issue Mark Rivers via Tech-talk
Prev: Re: motorSymetrie issue Mark Rivers via Tech-talk
Next: Synchronized format strings for PVs Patrick Hilhorst via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
