1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: [EXTERNAL] Java Status?
From: Kim Gillies via Tech-talk <[email protected]>
Date: Fri, 6 Dec 2024 11:45:38 -0500
Thanks Andrew,
The links are useful.  I’ll check them out.  I also see there is an exampleJava repo that looks good for coming up to speed.  I missed that for some reason.
Thanks again!
Kim
On Dec 4, 2024, at 4:51 PM, Johnson, Andrew N. <[email protected]> wrote:
Hi Kim,
Welcome back!
For using Java with EPICS you’ll want to look at Control System Studio and its newest CSS-Phoebus variant, which have taken over the maintenance and development of the Java implementations of CA and PVA. There still isn’t a Java-based IOC, but those UI tools and related middleware are more advanced and integrated than any other EPICS platform.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 12/4/24, 2:37 PM, "Tech-talk" <[email protected]> wrote:
Hi All,
I’ve been away from EPICS for several years.  I see a lot of progress has been made with version 7. The docs look really good and the build is much easier than it used to be.  Great job!
I don’t see much in the docs regarding Java, although I see there is an epicsCoreJava repo on GitHub.  I’m especially interested in PVA support in Java and whether it is possible to have any sort of Java-based IOC.
Can someone say what the status of Java is in EPICS and point me to any relevant docs?
Thank you!
Kim
Java Status? Kim Gillies via Tech-talk
Re: Java Status? Johnson, Andrew N. via Tech-talk
Prev: StreamDevice waveform record reports CALC error John Dobbins via Tech-talk
Next: Re: medm edit mode SIGSEGV core dump Ubuntu 24.04. Soliday, Robert T. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Java Status? Johnson, Andrew N. via Tech-talk
Next: EPICS Collaboration Meeting Spring 2025 - save the date Ivan Finch - STFC UKRI via Tech-talk
