Hi John,
A CALC error usually indicates there is input that cannot be parsed (https://urldefense.us/v3/__https://paulscherrerinstitute.github.io/StreamDevice/processing.html*proc__;Iw!!G_uCfscf7eWS!aXd-mh19ZX5invOHfuFM7T_LCXT9TRcLGBas0S7Zph-wRixPTU4ggOMIelbTGyFsQ55XqNlp_1wYkc-OcNSDB0Itv40Xbj8adS0$ ) and I noticed a : in the example you pasted 123108:240.0000 so if that is being added by the galil then it will likely cause the parse error in stream device. If this is a "feature" of the galil then you could try adding a stream device regex input pseudo converter https://urldefense.us/v3/__https://paulscherrerinstitute.github.io/StreamDevice/formats.html*regsub__;Iw!!G_uCfscf7eWS!aXd-mh19ZX5invOHfuFM7T_LCXT9TRcLGBas0S7Zph-wRixPTU4ggOMIelbTGyFsQ55XqNlp_1wYkc-OcNSDB0Itv40XcKPp9xQ$ to pre-parse the input and replace any : with a ,
Freddie
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Michael
> Davidsaver via Tech-talk
> Sent: 06 December 2024 20:12
> To: John Dobbins <[email protected]>
> Cc: [email protected]
> Subject: Re: StreamDevice waveform record reports CALC error
> On 12/6/24 07:56, John Dobbins via Tech-talk wrote:
> > All,
> > I am using StreamDevice to read into a waveform record. While it is working
> the waveform STAT = CALC. I have no idea what this is telling me.
> There are two places where CALC_ALARM appears in the stream source.
> Turning on (super) verbose debugging with the streamDebug iocsh variable
> might help to distinguish.
> > var streamDebug 1
> https://urldefense.us/v3/__https://github.com/paulscherrerinstitute/Stream
> Device/blob/668d1d525509604ab4ccd7382022dfb469c99841/src/StreamE
> pics.cc*L1083-L1085__;Iw!!G_uCfscf7eWS!aBhqEAW8eSGRZFZ7c0-
> EQ5M1p77k6VTomM1-
> _usJJCJ1xVPN8EitMeGQx6QJmH7JO9xZ8SxLRj1nVo26UneFqHKWMQ$
> pics.cc*L1461__;Iw!!G_uCfscf7eWS!aBhqEAW8eSGRZFZ7c0-
> EQ5M1p77k6VTomM1-
> _usJJCJ1xVPN8EitMeGQx6QJmH7JO9xZ8SxLRj1nVo26UnevSs6Xyw$
> > AsynTrace does not report any problems.
> > EPICS 7.0.2, StreamDevice-2-8-9
> > The record in question:
> > record(waveform, "ID5:SCCU19:array") {
> > field(DTYP, "stream")
> > field(FTVL, "DOUBLE")
> > field(NELM, "18")
> > field(INP, "@galil.proto get_sccu_array() $(PORT)")
> > field(SCAN, "1 second")
> > field(FLNK, "ID5:SCCU19:array_event") }
> > epics> dbpr ID5:SCCU19:array 4
> > ACKS: INVALID ACKT: YES APST: Always ASG :
> > ASP : PTR (nil) BKLNK: ELL 18 [0x1e0f870 .. 0x1e1a5f0] BKPT: 00
> > BPTR: PTR 0x1e2b1d0 BUSY: 0 DESC: DISA: 0
> > DISP: 0 DISS: NO_ALARM DISV: 1 DPVT: PTR
> > 0x1e2da80
> > DSET: PTR 0x844f60 DTYP: stream EGU : EVNT:
> > FLNK: DB_LINK ID5:SCCU19:array_event FTVL: DOUBLE HASH: 0
> > HOPR: 0 INP : INST_IO @galil.proto get_sccu_array()
> > MDCP_49
> > LCNT: 0 LOPR: 0 LSET: PTR 0x1e27c30
> > MLIS: ELL 0 [(nil) .. (nil)] MLOK: a0 b1 e2 01 00 00 00 00
> > MPST: Always NAME: ID5:SCCU19:array NELM: 18
> > NORD: 18 NSEV: NO_ALARM NSTA: NO_ALARM OLDSIMM:
> > NO
> > PACT: 0 PHAS: 0 PINI: NO PPN : PTR
> > (nil)
> > PPNR: PTR (nil) PREC: 0 PRIO: LOW PROC: 0
> > PUTF: 0 RARM: 0 RDES: PTR 0x1db7050 RPRO: 0
> > RSET: PTR 0x847020 SCAN: 1 second SDIS: CONSTANT SDLY: -1
> > SEVR: INVALID SIML: CONSTANT SIMM: NO SIMPVT:
> > PTR (nil)
> > SIMS: NO_ALARM SIOL: CONSTANT SPVT: PTR 0x1e30430 SSCN:
> > <nil>
> > STAT: CALC TIME: 2024-12-06 10:52:45.618293874 TPRO: 0
> > TSE : 0 TSEL: CONSTANT UDF : 0 UDFS:
> > INVALID VAL : PTR (nil)
> > The proto file
> > OutTerminator = CR;
> > InTerminator = "";
> > ReplyTimeout = 3000;
> > ReadTimeout = 100;
> > get_sccu_array {
> > separator=", ";
> > out "QU sccu[],0,17,1";
> > in "%f";
> > The command sccu[],0,17,1 request the elements of the array,
> sscu_array[], returned as a string with a comma as the separator.
> > :QU sccu[],0,17,1
> > 77.7463, -131.1270, 175.9897, 96.7502, 23666.0000, 23666.0000,
> > 23666.0000, 23666.0000, 23669.0000, 23670.0000, 23671.0000,
> > 23671.0000, -42.7689, 0.0000, 123108:240.0000, 23670.0000, 0.0000,
> > 0.0000
> > Any advice appreciated.
> > Thanks,
> > John Dobbins
> > Research Support Specialist
> > Cornell High Energy Synchrotron Source Cornell University
> > https://urldefense.us/v3/__http://www.chess.cornell.edu__;!!G_uCfscf7e
> > WS!aBhqEAW8eSGRZFZ7c0-EQ5M1p77k6VTomM1-
> > Z8SxLRj1nVo26UnfQCVDNrg$
> > <https://urldefense.us/v3/__http://www.chess.cornell.edu__;!!G_uCfscf7
> eWS!ar8DNSD3wtwletm5wJpAz9rza4Yc3Du1OJI0RHbbZn4HIUWallG1jM1gcP
> ZqJlwhcW
> > MQS5Yj8BvPTm3Icccqs8SiO_jEMaE$>
- Re: StreamDevice waveform record reports CALC error John Dobbins via Tech-talk
- StreamDevice waveform record reports CALC error John Dobbins via Tech-talk
- Re: StreamDevice waveform record reports CALC error Michael Davidsaver via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
