1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: EPICS Channel Access (PV access) to REST bridge?
Date: Wed, 11 Dec 2024 09:17:22 +0000
Dear Vincent
At PSI we have developed WICA "Web Interface for
Controls Applications", which provides:
- a backend service for streaming the state of
   EPICS channels over an http (REST) interface.
   It also supports basic get and put functionality.
- a frontend JS library that can interpret the
   event stream to update the html elements on a
   user's webpage in realtime.
The above is as far as it takes you; it's then
down to the user to develop the webpages that
leverage off this functionality according to
your needs and preferred technology choices.
The Wica backend service runs either as a fatjar
you can start on the command line, or as a service
you can run in a docker container.
WICA is an open-source project available on
GitHub here:
https://urldefense.us/v3/__https://github.com/paulscherrerinstitute/wica-http__;!!G_uCfscf7eWS!YlUlRnZjuChNXWDvxvrnblW7ubTr1zqMiFLpR5U_d5eyatYFsLK6cFDiXHOqpJp_mK5Pgf-tpCmPjRO_kkMseDpo$
Unfortuantely, currently there is no support for
PV Access.
Limited resources our end means we have had to
focus our development efforts elsewhere in recent
years, but it may give you some ideas.
Best regards
Simon Rees
Controls Software Engineer
Paul Scherrer Institute
RE: EPICS Channel Access (PV access) to REST bridge? Vincent van Beveren via Tech-talk
Prev: EPICS Channel Access (PV access) to REST bridge? Vincent van Beveren via Tech-talk
Next: Re: EPICS Channel Access (PV access) to REST bridge? Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: EPICS Channel Access (PV access) to REST bridge? Vincent van Beveren via Tech-talk
