1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: EPICS Channel Access (PV access) to REST bridge?
From: "Wang, Lin via Tech-talk" <[email protected]>
To: "Vincent van Beveren" <[email protected]>
Date: Wed, 11 Dec 2024 19:26:36 +0800 (GMT+08:00)
Hello Vincent,
Typically, caget and caput functions can be implemented via REST APIs, but the camonitor function needs to be implemented using WebSocket.
The following tools provide such functions,
1. epics2web
https://github.com/JeffersonLab/epics2web
It is maintained by JeffersonLab and supports Channel Access, but currently does not support PV Access.
2. pvws
https://github.com/ornl-epics/pvws
It is maintained by ORNL, supports both Channel Access and PV Access, but I did not find REST APIs for caget and caput (probably not difficult to implement).
If caget and caput REST APIs are needed in pvws, probably you can customize pvws and add them. For example, at CSNS I customized pvws and added pvget/pvput interfaces as follows,
https://github.com/wanglin86769/web-pvtools/blob/master/pvwa/src/main/java/pvwa/controller/PVReadController.java
https://github.com/wanglin86769/web-pvtools/blob/master/pvwa/src/main/java/pvwa/controller/PVWriteController.java
Lin
-----原始邮件-----
发件人: "Vincent van Beveren via Tech-talk" <[email protected]>
发送时间: 2024-12-11 16:07:23 (星期三)
收件人: "[email protected]" <[email protected]>
主题: EPICS Channel Access (PV access) to REST bridge?
Hi everyone,
Does anybody know if there is an EPICS to REST bridge? Meaning, being able to read/write (/monitor) process variables over a REST interface? Thanks!
Best regards,
Vincent van Beveren
Control System Engineer
Present: Mon - Tue - Wed - Thu - Fri
High Voltage Engineering Europa B.V.
Amsterdamseweg 63, 3812 RR Amersfoort
P.O. Box 99, 3800 AB Amersfoort, The Netherlands
Tel        +31334619741
Fax       +31334615291
E-mail   [email protected]
Web     www.highvolteng.com
RE: EPICS Channel Access (PV access) to REST bridge? Vincent van Beveren via Tech-talk
Prev: Re: EPICS Channel Access (PV access) to REST bridge? Rees Simon via Tech-talk
Next: RE: EPICS Channel Access (PV access) to REST bridge? Vincent van Beveren via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: EPICS Channel Access (PV access) to REST bridge? Vincent van Beveren via Tech-talk
