1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Building AreaDetector Vimba driver V 1.5
To: Steven Hunt <[email protected]>, Abdalla Ahmad <[email protected]>
Date: Mon, 16 Dec 2024 13:04:51 +0000
Hi Abdalla,
  • I still have no idea where this dbd file came from, but it seems to be not used anymore, I created a PR for this.
If you don't know where a file came from, then you should use "git log", which explains it clearly in this case:
(base) [epics@corvette ~]$ cd devel/areaDetector/ADVimba/iocs/vimbaIOC/vimbaApp/src/
(base) [epics@corvette src]$ git log Makefile
commit a23c8a17959c8dde461b745bf3dbcf906c0d28a1
Author: Mark Rivers <[email protected]>
Date:   Wed Jun 26 16:14:46 2024 -0500
    Add ADGenICamSupport.dbd for genicamShowFeature command
So ADGenICamSupport.dbd was added on June 26, 2024, in order to support the new genicamShowFeature from ADGenICam.  ADSpinnaker and ADAravis were changed the same way.
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Monday, December 16, 2024 1:58 AM
Cc: [email protected] <[email protected]>
Subject: RE: Building AreaDetector Vimba driver V 1.5
Hi Steven
Well we don’t have any IOCs based on ADVimba, but I cloned the latest version of the module and it compiled fine with our setup (ADCore 3.12, genicam 1.9, base 7.0.8), the only modification I did was in the configure/RELEASE file where I removed all includes and put dependencies locations directly:
EPICS_BASE
ASYN
ADCORE
ADGENICAM
And that’s it. A reference to include ADGenICamSupport.dbd is the iocs/vimbaIOC IOC and in my experience this happens if you have BUILD_IOCS = YES, which can be resolved by one of two choices:
  1. Set BUILD_IOCS = NO in configure/CONFIG_SITE
  2. Remove the line including the dbd file in iocs/vimbaIOC/vimbaApp/src/Makefile (Works with BUILD_IOCS = YES)
I still have no idea where this dbd file came from, but it seems to be not used anymore, I created a PR for this. I did not get the last warning, so I suspect there might be something with your paths definitions, maybe in configure/RELEASE or in the IOC’s configure/RELEASE.
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Steven Hunt via Tech-talk
Sent: Sunday, December 15, 2024 11:44 PM
To: [email protected]
Subject: Building AreaDetector Vimba driver V 1.5
Hi I am attempting to build the Vimba driver V1.5 downloaded today  from git.
I was previously  using V1.4
I have not updated other packages -  such as ADCore, ADGenICam etc
It fails looking for  file 'ADGenICamSupport.dbd' which I don't have under ADGenICam (which has no dbd directory) or indeed  anywhere in my areaDetector-R3-11 tree, and was therefore seemingly not needed by R1_4 ?
make also reports :
Your Makefile may need this dependency rule:
    $(COMMON_DIR)/vimbaApp.dbd: $(COMMON_DIR)/ADGenICamSupport.dbd
Which is a red herring?
Re: Building AreaDetector Vimba driver V 1.5 Steven Hunt via Tech-talk
RE: Building AreaDetector Vimba driver V 1.5 Abdalla Ahmad via Tech-talk
Prev: Re: Building AreaDetector Vimba driver V 1.5 Mark Rivers via Tech-talk
Next: Re: Building AreaDetector Vimba driver V 1.5 Steven Hunt via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: RE: Building AreaDetector Vimba driver V 1.5 Abdalla Ahmad via Tech-talk
